1969 Ford Crew Cab / Cummins Project
FormerMarine1981
Re: 1969 Ford Crew Cab / Cummins Project
Post by FormerMarine1981 »
:pop: :pop: :pop:
fomocoguy
Post by fomocoguy »
:yt: I wonder how many hours of labor will be invested in this truck.... HRDROKN, you are keeping track, right? :lol:
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
HRDROKN
Post by HRDROKN »
Worked on getting the twins assembled today... what a PITA! There just isn't much room to do anything and the fit is so dependant on all the factors being just right. I also polished out the S400 compressor and still need to build the cold pipe....
:hmm:
'69 Ford Cummins Crew Cab... Built 6BT main & head studs, ported & oringed head, springs, Ti retainers, marine cam, tweaked P7100, 4K gov kit, NV4500 w/1.375" input, Southbend 3600# DD clutch, NP271 w/SYE, D60 HP front, high steer, 16" coilovers & 4-link, D80 w/disc rear, 4.10's & LSD, spinning 38" x 14.fiddy's on classic slots..... more coming!
http://www.fordification.com/forum/view ... hp?t=23267
HRDROKN
Post by HRDROKN »
Oh, BTW......
Looks the holiday screwing off is over also and I feel that I'm about fished out now. So I started working on some miscellaneous stuff before diving back into the suspension!
Gauges....
:wink:
BobbyFord
Post by BobbyFord »
Sweet!! :thup:
1971ford
Post by 1971ford »
WOW.... is that a F600 panel with the center cut out with your own sheet work? That is super slick.. I'd like to do the same.
-Ryan
HRDROKN
Post by HRDROKN »
1971ford wrote:WOW.... is that a F600 panel with the center cut out with your own sheet work? That is super slick.. I'd like to do the same.
I think that was the stock F250 panel.... heck, it's been so long I forgot what it originally looked like! Yes, I cut the center out and fitted a new .125 aluminum center section.
:wink:
1971ford
Post by 1971ford »
Nice. I thought it was a f600 cluster becaues of the chrome inside but now that i think about it the originals probably do have the chrome too.
-Ryan
HRDROKN
Post by HRDROKN »
Out with the vacuum assist and in with the hydroboost....
:D
82GT
Post by 82GT »
This build is awesome!!
JZ
This space for rent
sport71
Post by sport71 »
when are you going to finish this awesome truck?
Those who do not learn the lessons of history, are doomed to repeat it.
HRDROKN
Post by HRDROKN »
sport71 wrote:when are you going to finish this awesome truck?
Probablly never finished..... but I do expect to be driving her this summer!
:hmm:
mljjones67
Post by mljjones67 »
What hydro boost did you use?
HRDROKN
Post by HRDROKN »
mljjones67 wrote:What hydro boost did you use?
That hydroboost is a 91-97 F250/F350 application.... just had to rotate the bracket 180* and re-drill two of the holes. My peddle height will be about the same as it was.
:wink:
