Interesting find on my crossmember.
67F250CS
Post by 67F250CS »
Well as most of you know I have been swapping an FMX for favor of a C-6.
I was getting ready to bolt the trans mount on the crossmember and saw little letters stamped on my crossmember. It has AUTO8 stamped very near the center where the mount goes. I am guessing its a auto only and V-8 only crossmember. I thought they were all the same. Any one seen this before? :hmm:
Pictures arent great but you can see it a little.
1967 F250 Camper Special
fordloaf
re: Interesting find on my crossmember.
Post by fordloaf »
Interesting... if you dont need your FMX anymore could i have your dipstick off it?
trukcrazy
Post by trukcrazy »
Keith, there's your next item of trivia for "Did you know?". Interesting.
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
67F250CS
Post by 67F250CS »
fordloaf. My dipstick is pretty thrashed. I saw your earlier thread about needing one. Mine is missing the top cap also. Just a metal stick stuck down a slightly bent tube. Its ugly dude, sorry.
Hmmm....I've never seen this before. I'll have to check out the three or four I have laying around the shop and see if there's something similar on them. Thanks for the heads-up! :thup:
cdeal28078
Post by cdeal28078 »
I've never seen it either but I used the same cross-member under a 3 speed manual,C-6 auto and an AOD overdrive just by moving it backwards into holes that were already drilled.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
