Rear lowering block kit?
- 1968flareside
Does anyone make these for our trucks or a universal setup? While I have the bed off, I'd like to lower the rear a couple inches to level the truck.
1968 F-100 Flareside
1999 F-150 XLT 4X4
http://www.fordification.com/galleries/ ... ?cat=10023
and
DON'T FORGET!!
1999 F-150 XLT 4X4
![FTE SUCKS :fte:](./images/smilies/icon_ftesux.gif)
- 67F250CS
re: Rear lowering block kit?
AIM Industries used to be up in Phoenix. Probably still there. I went there a long time ago to look at there stuff. I think they sell a shackel kit. ( Chassis Tech ) It puts the spring mounting points up thereby lowering the rear of the truck.
Found it in Mesa,
AIM Industries
Dept. TR
260 S. Hibbert
Mesa, AZ 85201
(800) 842-8789
(480) 668-5448
www.aimind.com
www.truckin.com
Chassis Tech
Dept. TR
234 S. Hibbert
Mesa, AZ 85201
(480) 898-9049
www.chassistech.com
Found it in Mesa,
AIM Industries
Dept. TR
260 S. Hibbert
Mesa, AZ 85201
(800) 842-8789
(480) 668-5448
www.aimind.com
www.truckin.com
Chassis Tech
Dept. TR
234 S. Hibbert
Mesa, AZ 85201
(480) 898-9049
www.chassistech.com
1967 F250 Camper Special
- 67F250CS
Go to the AIM site and put in "Lowered Trucks not Air" in the little drop down box. Then select the Ford logo. You will see there product line for our trucks.
- 1968flareside
Great thanks!
1999 F-150 XLT 4X4
and
DON'T FORGET!!
1999 F-150 XLT 4X4
- boots
Re: re: Rear lowering block kit?
67F250CS wrote:Go to the AIM site and put in "Lowered Trucks not Air" in the little drop down box. Then select the Ford logo. You will see there product line for our trucks.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- GT-Racer
The new rear springs are said to give 2-3 inches of drop with no loss of ride quality. For only $169 that would be the route I would take.
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....![Smile :)](./images/smilies/icon_smile.gif)
- 1968flareside
I was looking at the rear suspension tonight. The leaf springs are OVER the rear axle! Is that right for a F100 2wd or did someone probably do this to the truck? All I want to do is level the thing out. Here's the best picture I have of the difference between the front and rear ride height.
1999 F-150 XLT 4X4
and
DON'T FORGET!!
1999 F-150 XLT 4X4
Yes, the springs supposed to be mounted over the axle. That's where the rearend flip kit comes in, to mount them below the axle to get the back end down lower.
- 1968flareside
So, the kit is a must, huh?
1999 F-150 XLT 4X4
and
DON'T FORGET!!
1999 F-150 XLT 4X4
Well, there are other ways of doing it, but......yes, it's a must! ![Wink ;)](./images/smilies/icon_wink.gif)
- customcrewcab
well you could make your own lowering blocks. i hate the aluminum ones.
i broke a bunch of them. if your going to make some hp make some out of steel. get some square tube and drill a hole straight through. tread one side and put a allen head in the other side. make sure you get the tight size head. the aluminum is cast and likes to break then fall out.
![Image](http://www.fordification.com/images/forum/ty.jpg)
- 1968flareside
But simply using the lowering blocks by themselves wouldn't work with the current factory setup. I would still have to get the leaves under the axle. Which, according to the AIM site, will lower the rear 5-6 inches. That is about half the price of what is GT Racer mentioned...
BOTP lists them, but they are almost 400 big ones and only offer a 2 inch drop.
And, hate to say, AIM doesn't show the rear leaves for our years. They are newer years only. http://www.truckn-store.com/product.asp ... p&ID=85121"GT-Racer Posted: Wed Sep 14, 2005 6:25 pm Post subject: re: Rear lowering block kit?
The new rear springs are said to give 2-3 inches of drop with no loss of ride quality. For only $169 that would be the route I would take."
1999 F-150 XLT 4X4
and
DON'T FORGET!!
1999 F-150 XLT 4X4
- GT-Racer
Sorry I just saw the price and didnt open it to see if they had our years.
- 1968flareside
No sweat! It's easier on their site to plug in the make, model, year, and category.
1999 F-150 XLT 4X4
and
DON'T FORGET!!
1999 F-150 XLT 4X4
Go the AIM route. I have the shackles and hangers for the rear and the drop i-beams for the front. Haven't installed yet, but the shackles and hangers look fairly simple plus the sell the 2 degree pinion correction "blocks". Shackles were $69/pair and hangers $99/pair pinion shims $18/pair. You will also need shocks if going more than 2" - $88/pair. Hope this helps!
