How do you remove the dash pad?
Is it on with clips that pop off?
there should be little nuts under the dash youll need to take out your glove box and intrument panel it realy easy just alittle hard to fit your hand in there just pull that stuff off and have a look (DO NOT try to pop it off it will crack,tear) let us know if you have any more Q's i think the nuts are 3/8 or 7/16's it something small like that ,there is alot of the nuts though
"Gas' Guzzler fer life" "Southern Pride""It's not what you buy it's what you build"
re: How do you remove the dash pad?
Thanks for the tip. So how do i get the instrament panel out? Just screws?
Yep...just remove the Phillips-head screws you see around the perimeter of the instrument panel as you're looking at the front....four on top, four on bottom. (this is for the plastic panel...if you've got a metal panel, don't take the four middle screws out, as those are the ones which hold the gauge cluster to the back of the panel.) You might want to reach up under the dash and disconnect the speedometer cable and harness connector first though...often times they're not quite long enough to allow you to pull the instrument panel out far enough to get to them that way.
- Bobaloo2
Unscrew the speedo cable and do the screws, you might get enough room to get in there without disconnecting anything, (expect scratches to your hand, a lot of edges up in there, or am I just careless???)
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
- flyboy2610
You might need to remove the glove box liner, and possibly the heater core box, to gain access to all the bolts.
When you do get all the nuts off, you may still have to pull on the dash pad to get it off. Being in the sun for over 30 years, these things tend to become 'glued' to the metal dash.
Here are some pics showing the location of the bolts. This is the dash pad from my '68, Frankie.
- jor
And here's some photos from under the dash to compliment flyboy's.
jor
jor
Thanks guys. Wish me luck! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
why are you taking it off. for a different one? or for a repair of some kind? the reason i ask is that my pad doesn't have any cracks but the speaker part is all rotted out. i have been thinking of a way to repair it but i'm not sure if i can find some sort of chrome trim to go all the way around the speaker hole so leaving the metal speaker hole open. maybe.
- flyboy2610
Be sure you get what it is you want. I have seen for sale both dash pads, which is what is in the truck from the factory, and dash COVERS, which is a piece of material you lay on top of the dash pad to dress it up.
Make sure of what you are ordering.
