Post your 4X4 pictures HERE!!
Re: Post your 4X4 pictures HERE!!
I like the color. Are you going to keep it orange?
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- big orange
Yes. the paint is still in good shape but its starting to rust in some seams
I cut it twice and its still too short!!
Is this the stock hight or have you lifted your truck any,if its stock have you had any tire rubbing problems,ive got a 69 highboy thats apart and just thinking about tire sizes and stuff before i start putting back together.how many RPMs you turn going 60 mph,,,,nice color ive thought about orange when i paint mine
- big orange
Its got a leaf spring dana 44 soa disk brakes and power sterring.. not sure actual lift. Plus 3" body lift so im thinking around 6" or 7" total lift?? 35x12.50 BFG A.T.'s on 16.5x9 eagal alloys. dont have any clearance issues at all im thinking about 36x12.50x17 for my mud tires :hmm:Not sure about RPM's i hope to get a 5" tach for christmas!!
Heres some of my bumps. I hope this works new at posting pics. Sorry cant get the pic to show up don't no how.
<a href="http://s948.photobucket.com/albums/ad32 ... cks101.jpg" target="_blank"><img src="http://i948.photobucket.com/albums/ad32 ... cks101.jpg" border="0" alt="Photobucket"></a>
67 Highboy with 427FE 79 dana 60 front dana 70 rear 13" of lift 38" swampers. 72 F100 2wd short bed 302 toploader 4speed. 71 F100 shortbed 4x4 rust bucket. 68 F100 2wd long bed parts truck no rust.
- fireguywtc
Here ya go!4x4freakfe427 wrote:Heres some of my bumps. I hope this works new at posting pics. Sorry cant get the pic to show up don't no how.
Bill
That's a cool pair!!
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
55F100
- big orange
I like the lift
1990 Mazda Miata 1.6 turbo
2010 Audi S4
1967 F100 4x4 4spd
2010 Audi S4
1967 F100 4x4 4spd
Hey man thanks for the boost. I am still trying to get this kind of thing down.fireguywtc wrote:Here ya go!4x4freakfe427 wrote:Heres some of my bumps. I hope this works new at posting pics. Sorry cant get the pic to show up don't no how.
Thanks for the complements guys.
- zakt
4x4freakfe427, that lift with the highboy boy 4" block or just 13" springs or?? Want to put some 37" tires on mine but thinking 8" spings +4" high boy blocks or just a straight 12" spring with no blocks?
Todd
Todd
1972 Ford F350 crewcab
Well I did mine custom becase when I built my truck I did not have much money to work with. So I used chevy 6" lift springs front and rear. In the front I added some 3" tubing under the frame and moved the ford hangers to work with the springs I used. I will be changing this set up down the road to some super duty springs. In the rear I used chevy 4x4 rear spring hangers and shackles and drill new holes in my frame to make this work the rear springs are sitting on top of 1 1/2" blocks. On chevy 4x4 trucks they did not use a lift block but there hangers hang down lower than the ford ones, but ford has the factory blocks.zakt wrote:4x4freakfe427, that lift with the highboy boy 4" block or just 13" springs or?? Want to put some 37" tires on mine but thinking 8" spings +4" high boy blocks or just a straight 12" spring with no blocks?
Todd
I also have a 3" body lift. I hope I kind of helped you out. before I did all of this to my truck it had 7" of lift and it cleared 35", so if you are looking to run 37's I would run at least 9"s or more to make sure you don't rub the fenders. I some times run 42" tires on my truck and I rub the front fenders some times.I would post more pics but unsure on how to get them here. Mike
- 72Highboy
Here is my 1972 Ford F100 with a 5.9. Just a lil fixer up, every common problems come with it but it gets from point A to B
It was just a couple snow days that passed through EP Texas.
Joshua
aka Young Gun
FE - Famous Engine
(Brandi) 72 F100 360 5.9L Sport Custom 6" Lift
U.S. Army Veteran/11B
aka Young Gun
FE - Famous Engine
