air tank volume
air tank volume
i now have a 1/2 drive impact. and a 22 gal compressor. both are brand new almost. the impact wont break loose alot of bolts that i need broek loose. it is because i dont have enough air or volume of air to get the full use of the impact. i know i really need a larger compressor to do the real job. but money isnt free and niether is a larger compressor. but i do have other tanks around here i could use as add ons. or aux / extra tanks to hold more air.
would using those extra tanks to hold more air do what i am wanting? or would they just hold more air for longer duration. rather than giving me more volume?
- Sam I Am
Re: air tank volume
Check the rated torque of your impact, it may not be strong enough to do what you want. If it is rated high enough to do it, you may need to turn the adjuster knob to a higher setting.
As long as your compressor builds up enough pressure, your tank doesn't leak, and you have the proper sized air hose diameter, your impact will do it's job for several seconds at least until the tank pressure drops. I've used impacts with a lot smaller tanks than you are using and usually the limitation is the tool itself, not the tank or compressor.
Back when I was doing mechanic work, Mac made the best impact wrench. I haven't shopped for them lately, so I can't recommend what to buy now, just check the torque rating and make sure it is higher than what you need it to do.
Also, it is a good idea to clean the threads with a wire brush before you try to twist off a nut. And using Liquid Wrench or PB Blaster really helps if it is rusty.
Re: air tank volume
its not the impact. its a brand new snapon mg725. it works great on larger tank compressors. maybe my compressor isnt kicking back on soon enough.
Re: air tank volume
Get some bigger couplings that flow more volume. (Milton 1009 series ?)
The school where I worked had the air regulated down to 100 -120 psi for safety , and with the high flow fittings we had no problem. Also get at least a 3/8" air line 1/4" doesn't cut it.
Re: air tank volume
i have my air settigns about 100 i think . i am pretty sure i have the 3/8 line. i have the milton M style couplers.
Re: air tank volume
100 psi is a little low I like at least 120.
I looked on the Milton site and the M style flow 40 scfm.
The P style I use flow 68 scfm and they have others that flow more yet.
Try a little more psi and see if that helps .
Re: air tank volume
i'll turn it up this weekend. but i may only be turning up the tank pressure but not the holding capasity. or will thr stock swithc on the compressor turn up line pressure? i guess it might if the kick on pressure is at 120 instead of 100.
- TNIceWolf
Re: air tank volume
Careful you dont go over the tanks rated limit fordman. Having a tank blow out really sucks......trust me. Had one blow awhile back and I didnt really care for the experience much!
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
Re: air tank volume
Fordman what's your compressor rated at CFM wise?
Re: air tank volume
idk i havent used the impact since this post. i've only aired up some tires so i havent even looked at it.
Re: air tank volume
I'd be willing to bet the CFM is a little too low to use the impact at its best, its not so much the tank size, its the volume the pump can put out. Tank size will just give you more time between cycles. According to snap-on's website you need 5 CFM at 90 psi
Re: air tank volume
Semi-related.... Has anyone thought about, or actually added a 2nd tank to their air compressor?
I found this on craigslist And was wondering how it would work adding it to my existing 60 gallon air compressor/tank setup.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
Re: air tank volume
i dont know but i would try it if it were me. mine is too small i think.
Re: air tank volume
Adding a second tank IMO is just a waste (unless you've got a 2-stage pump). You're really not gaining anything except more reserve until the pump has to cycle again. But once the pump does start up, it's going to have to run longer to bring the pressure back up to the preset PSI to two tanks instead of just one...which could lead to the pump overheating.
If you want to do any upgrades to a single-stage compressed air system, go with a bigger pump with a longer duty cycle, preferably a 2-stage pump. And/or get a good dryer. IMO that's where you'll see the most noticeable improvement.
