1971 bump put on a 92 f-250 frame
- jdf
has anyone on here ever do this swap . i have a 1971 bump i would like to put it on my 1992 f-250 frame . any info on this swap would be appreciated . maybe some pics of one that has been done ?????????????????
- 1971ford
Re: 1971 bump put on a 92 f-250 frame
I don't think ive ever seen this done to such a newer frame.
I take it you have some fabrication skillz? Because you will need them!
-Ryan
Off the top of my head I believe the newer frames are wider and have a different shape to them.
Also since you posted this in the 4x4 section what kind of advantage are you hoping to gain from the newer frame?
Personally I would box the older frame before I bothered with a newer frame.
Specs for the frame and the bump would be useful to.
71 3/4 ton 4x4 highboy
68 Mercury Monteray
68 Mercury Monteray
- jdf
the bump is actually a 2 wheel drive. the 92 is a 4 wheel drive that i have a new windsor in and a sterling rear end and a lot cleaner frame . thought also by going this way i would be saving liscense and insurance on 2 trucks by combining the 2 trucks into one . would like to find someone who has done this swap already to get their opinion on it .
http://s780.photobucket.com/albums/yy84 ... 2b661b.pbw
it can be done...this 60 year old car body rests comfortably on a 71 bumpside frame ,,,
i also have a 52 international pickup that i put on a 75 highboy frame,,,
and a current project ,,my uncles 50 ford panel...we put on a 1990 f-150 4x4 frame theres alot of variables but it can be done
here is the 52 international l-110 this truck has an actual 9 foot bed!! i had to cut and lengthen the chassis (75 highboy)19 inches to catch the wheel base though,,one hurdle to jump,,many more after that
- jdf
cool looking projects guys . i am having second thoughts now about this swap . i have a 1975 high boy frame to use also .this might be my better way . my 1971 bump is rust free well worth the trouble to put it on a 4x4 frame .the bumps look so cool setting on a 4x4 frame with 35 x12.50 tires aluminum slots and a 4 inch suspension lift
- SteveC
let me put it this way... im in the middle of this swap...and its way easier to just swap frames.... i can just look at the two frames and see a world of difference in just the shape.
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- adrianspeeder
I wouldn't do all that work to only have a Dana 50 TTB under the front end.
Adrianspeeder
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
- 1967AceStroker
I know a guy that has a '67 crew cab bump on an '05 Superduty frame. This thing is highly modified, he went all out. Which reminds me, I never went to get pictures of it, I'll have to go do that soon.
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
- Redcap
Good call.adrianspeeder wrote:I wouldn't do all that work to only have a Dana 50 TTB under the front end.
Adrianspeeder
I no a guy who did this he took a 69 bump and put it on a 97 frame but the only reson he did this swap is because of the 7.3 disel and 5speed and he is running the sterling and a 60 front. He even used most all of the interior out of the 97. He did a good job but he has alot of time and work in it. The only thing I did not like about his swap is the gap between the bed and the cab was like 3" so I think the wheel base is a little different. I say anything is possible it just depends on how much work you want to do and the kind of tools you have to work with.
As with the TTB 50 you could always change it over to a 60 later down the road.
67 Highboy with 427FE 79 dana 60 front dana 70 rear 13" of lift 38" swampers. 72 F100 2wd short bed 302 toploader 4speed. 71 F100 shortbed 4x4 rust bucket. 68 F100 2wd long bed parts truck no rust.
Cool project, I have a '56 S-120 someone put a 304 in, they cut the frame, remounted the steering box and on and onrattlehead_74 wrote:here is the 52 international l-110 this truck has an actual 9 foot bed!! i had to cut and lengthen the chassis (75 highboy)19 inches to catch the wheel base though,,one hurdle to jump,,many more after that
I was thinking of putting the body on an '86 F350 4x4 diesel...
I would like to see how yours turns out
![Image](http://i248.photobucket.com/albums/gg166/jjames72/IHC010.jpg)
![Image](http://i248.photobucket.com/albums/gg166/jjames72/IHC023.jpg)
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
'72 crew 4x4
'07 KTM 450 xcw
Sorry for ![Thread hijacked :hj:](./images/smilies/icon_hijacked.gif)
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
'72 crew 4x4
'07 KTM 450 xcw
