FE Experts Please Come In
4dtrks
Post by 4dtrks »
Its been a lil while since I was here, but Im back!
Ive got some questions about the top end on my 390. First off I was lookin for a little insight on the heads I picked up way back when. They are P/N C4AE-6090G, and I used them to replace my C8AE-H heads. If anyone has any info on the performance potential of the heads that would be great. Ive heard stories, just lookin for confirmation on what Ive heard. In one of my parts books it says that the C4's and C8's have the same size ports, but they clearly didnt. I remember the C8's being reffered to as the "Short Port" head, is that correct? Also, what are the potentials for the C8's? Should I find an intake to match the C8's instead of havin one that matches the C4's?
Next, is my C5AE-9425C intake. With a quick sloppy measure, the runners were close to the C4's so I bought it. Is this manifold an ok match? Or, like I asked above, should I just find an intake to match the C8's and swap the top end? Either way, does anyone know a P/N for the manifold that would match C8's?
Sorry for the lengthy post, but thanks for reading.
Locate approximately as shown.
427
Re: FE Experts Please Come In
Post by 427 »
Im no expert but I have worked on fe,s a little bit. My advice would be get cobra jet heads and a good aluminum intake. Im not sure the part # on the heads but they have dual bolt patterns on the exhaust side. They are also the same as 427 low-riser heads. Hope this helps, Brian.
68 f100 427 r code 4spd toploader
69 f350 390 4spd hauler bed
72 Ford Bronco 302 3spd
95 Ford Lightning
38 John Deere G
Assorted old Honda ATC,s
fomocoguy
Post by fomocoguy »
I'm sure somebody here will eventually come up with the info you're looking for as there are a lot of FE gurus around here, but if you want quick answers from a great FE resource try this forum: http://www.network54.com/Forum/21142/ This is the FordFE forum that everyone talks about. Good luck!
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
Darren
Post by Darren »
That's the same casting number on my new heads. They came off a 1964 galaxie 500.
"Do it now, or wish forever that you had."
