Exhaust Question
- Black69F250
Exhaust Question
Does anyone know what the pipe size is on a 360 390 engine? I am looking for the spec on the outside diameter of the pipe coming from the manifolds to the muffler.
Raven Black 69 Camper special
Re: Exhaust Question
2 1/2 is the size used. i have no idea if that is outside or inside measurements.
- Black69F250
Thanks... That's most likely the outside measurement. The muffler will be 2 1/2 inside to be able the slip over the header pipe.
- sideoilerfe
The exhaust pipe going to the muffler is 2 1/2. If you buy a muffler with a 2 1/2" inlet it will slip right over the pipe.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
to updat emore on my situation. i was looking through the diagrams. and it seems the f250 f350 and 4wd all use the same pipe as my f100 4wd. i checked every part store in town. and onl one can special order the pipe. if i tell them it is a 73 f350 4wd. because the eninge is a 73 and the front axle is a 74. if i try for 71 f350 4wd i get nothing as far as a part. is there a difference in the 73 manifold vs the 71 drivers manifold? that is all i can think of as far as the difference. i have the 73 and up drivers manifold.
A related question - I have a 1970 F100, 360, 2wd - this is a helpful thread, b/c my muffler & tailpipe fell off yesterday - I can get the right size muffler & tailpipe, but not sure how to attache the muffler on the front end - the pipe is there, intact, no rust, just nothing to bolt to
1970 F100 Sport Custom Farm & Ranch Special, 360, 3sp, bone stock!
all of the mufflers and tailpipes are held on by muffler bracket hangers. where ever you can botl them to is goignt o hold it up. usually the hangers are in places such as the frame and rear cab mount crossmember. as well as other places. http://www.fordification.com/tech/image ... aust03.jpg
Thanks - got that part - familiar with loose hagars and such - but how do I connect the muffler to the pipe coming back from the Y pipe?
one fits inside the other. if you cant find an orginal get a glass pack. i guess.
ok - just slips in - no need to weld?
Duh! Thanks!
