"Extra Heavy Duty" Power Steering Pump from 78-89?
DuckRyder
Post by DuckRyder »
NPD list an Extra Heavy Duty pump it doesn't specify an engine, but it appears that bolt patterns are somewhat "universal".
Anyone tried one of these?
'75-4x4guy
re: "Extra Heavy Duty" Power Steering Pump from 78
Post by '75-4x4guy »
it is the pump with the plastic res.
I think the innards are just beefed up ....
Jon
customcrewcab
Post by customcrewcab »
innards :lol: i love that :D
DuckRyder
Post by DuckRyder »
It says that it is cast iron with a steel reservoir vs aluminum and plastic. It says it is larger stronger and quieter than the OEM ford pump.
460 crew
Post by 460 crew »
How much more is it that a stock pump? :?
