hose diagram
hose diagram
can someone send me picture of the air vacum hoses for a 390/360 2brl.on the carb .valve cover.thanks
Re: hose diagram
they are on the site somewhere but i cant finsd them. i know i saw them the other day when i was looking fo rsoemthing else. start at the site index and start checking everything that it might be listed under.
Re: hose diagram
bump can someone send me some pictures of the 390 with the air cleaner on if you have one.thanks
- robroy
Re: hose diagram
Hi Emilo2008!
I'm not sure how much help these two pictures will be to you, since they were taken at various stages of tear-down. Click on the links below each image for a large resolution version, if you want to see anything in greater detail.
![Image](http://www.robroygregg.com/Number50/IMG_5170ss.JPG)
http://www.robroygregg.com/Number50/IMG_5170s.JPG
![Image](http://www.robroygregg.com/Number50/IMG_5172ss.JPG)
http://www.robroygregg.com/Number50/IMG_5172s.JPG
Also, Keith posted a bunch of photos saved from an eBay ad of a 1970 pickup with 358 original miles. It has an FE in it and there are a few engine bay photos--here are some that might interest you.
![Image](http://www.fordification.com/images/70explpics/15.jpg)
![Image](http://www.fordification.com/images/70explpics/16.jpg)
The rest are here:
http://www.fordification.com/70explorer_358miles.htm
The rest are here:
Re: hose diagram
We also need to know if the truck has the Distributor Modulator setup, or if the engine is equipped with the TRS (Transmission Regulated Spark) setup, used on '70-'72 F100s.
Re: hose diagram
thanks for the picture.its without the emission module .can someone tell me where does sthe outlet tube in back of the 2brl carb on the passanger side go to.
