UM - O.K.
I would love to hear his explanation of how removing the plug wire would affect a rocker or pushrod.
Bad wrist pin? (video included) (300 6)
Re: Bad wrist pin? (video included) (300 6)
- 70_F100
That's not an oil leak
Looks like I can't give you guys an answer on that, not tonight anyway.
So I was on my way to go show that guy the noise. About 2 miles into the drive the engine starts running like crap. I stop in a gravel turn off and pop the hood and there is gas pouring out of the carb. Take the top hat off, reset the needle and float, put it back in and it runs... kinda. Made it back home barely. So now I am back to where I was two weeks ago.
Float is intact, needle valve is seated and functioning. Where do I go from here? I just cleaned and rebuilt it.
- 70_F100
Did you replace the fuel filter when you rebuilt the carb?
No I didn't. Does it live in the pump housing?
- FoMoCo
Before you look for another block keep in mind it'll need to have an opening for a mechanical fuel pump, and drilled and tapped for a clutch pivot stud.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
I opened the carb and guess what? There was a spec of crap where the needle seats. Sprayed it out, reinstalled and got a new fuel filter for good measure (old one wasn't even dirty after 10+ years). Drove to the gas station and filled the tank back up- drives fine now.
As for the noise I won't be able to report back on that till Friday. Have military stuff to do.
- mkpj1
I'm with DR on this but let us know. 85 means a rebuild where I come from.
To bad you are on the other side of the sun soldier or I'd give you a V8 setup I have for sale. Perches to drive shafts brother for doing what you do. Square you away so to speak.
Carry on. OOhah!
Ken
Carry on. OOhah!
Ken
Ken
Greenville, SC
68 F100 LWB 390
67 LTD 390(4V T-bird Special)
74 Bronco 351W
"I sincerely believe... that banking establishments are more dangerous than standing armies, and that the principle of spending money to be paid by posterity under the name of funding is but swindling futurity on a large scale." --Thomas Jefferson to John Taylor, 1816. ME 15:23
Greenville, SC
68 F100 LWB 390
74 Bronco 351W
