Roller Lifters
Roller Lifters
Can someone explain how these work. I know what they do sort of, do they still take pushrods? Explain please.
- 70_F100
Re: Roller Lifters
They are pretty much just like a flat tappet, but they have a roller on the bottom.
That's not an oil leak
- 70_F100
Re: Roller Lifters
Push rod.
Like I said, just like a flat tappet, but with a roller on the bottom.
Re: Roller Lifters
http://www.pacificperformanceracing.com ... lifter.jpg
heres a good picture that kinda explains them. the top side looks the same or very similar to a normal hydraulic lifter if im not mistaken (someone verify this). are you asking about the little link that connects 2 of them together?
- 70_F100
Re: Roller Lifters
That's a guide to keep them oriented correctly, so that the roller is parallel with the cam lobe.
Re: Roller Lifters
im pretty new to the rocker roller deal. but isnt that a complete upgrade? using the tin plate to hold down the lifters and then adjustable rockers?
Re: Roller Lifters
For what engine? (specifically)JMcTurnan wrote:So if I went to those what all would i need? Just new rods?
By "rods" do you mean the links? There are diffrent kinds too some are made onto the lifters some not.
At any rate and reguardless of what you mean by "rods" the answer to your question is "no - that isn't all you need".
This might answer some of your questions:
http://www.compcams.com/Technical/FAQ/FAQLifters.asp
Re: Roller Lifters
Yea I meant the actual "Rods", so then its a little more complicated then
- Redcap
Re: Roller Lifters
You mean "pushrods"?JMcTurnan wrote:Yea I meant the actual "Rods", so then its a little more complicated then
It's a lot easier if you use the correct terminology, rather than some shorthand crap like "dizzy".
Re: Roller Lifters
dizzy doeshe? dozzy dozer. doozy? wake up. i think i am dizzy now. i'll get a pic of the inside of a 302 ho. it has the intake off of it. its a 94 model engine.
Re: Roller Lifters
No one can accurately answer his question until he tells us (again SPECIFICALLY) what he is working on, even if it is a small block it matters if it is a roller ready block or not.
Seriously, I hate to see someone not get the help they need but I have to assume someone who is not responding to request for information from them in order to properly respond to their question, just really does not want the help.
- 70_F100
Re: Roller Lifters
