Fe Block Identification
rabbithunter2005
Post by rabbithunter2005 »
I picked up this 390 that was seized up for 50 bucks just for the rear sump oil pan several months ago. I used the pan to put a 390 in my 85 pickup so all went well there. Now that that project is done i'm looking at starting another one. I still have this 390 block and i was looking at it the other day and i noticed that it had ribs going up and down the outside of the block. The 390 i put in my truck doesn't have this and i've never seen this on any other blocks. Is this a special block or somethin. Any insight is greatly appreciated Thanks.
1969 ford f100 351w aod
1967 f250 4x4 351c m50d
Re: Fe Block Identification
the ribs denote that it is a factory service block or factory replacment block. it not speical. i have one of them its worth less than a regular block. hurray for me. im not rich im even poorer since it takes up space.
DuckRyder
Post by DuckRyder »
Later FE blocks had that.
sideoilerfe
Post by sideoilerfe »
How late? My D3TE and D4TE blocks do not have that. I've been wondering about that myself as I have a block with those ribs and without date code castings.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
DuckRyder
Post by DuckRyder »
Intresting, It was my understanding that they started around 71, are your D3 and D4 blocks cast at MCC or DIF?
Of course where FE castings are concerned, you just never know... :wink:
the ribbed block i have is DIF. that is all it says on it.
sideoilerfe
DuckRyder wrote:Intresting, It was my understanding that they started around 71, are your D3 and D4 blocks cast at MCC or DIF?
I'm not sure. I no longer have the D4TE block but i still have the D3TE. It is in the truck.
DuckRyder
Post by DuckRyder »
Then I am not sure. I know it has been said that MCC produced cleaner castings so perhaps they were deemed no longer needed for whatever purpose they were to serve. It has been a few years since I did much study on it but I do think that I have even heard of blocks that had them on one side and not the other.
They do not indicate any thing "special" about the block though I am sure of that.
DuckRyder
Post by DuckRyder »
Here is just one thread on it at FE Forum.
http://www.network54.com/Forum/74182/th ... d+Block---
I would go with Dave Shoe on this; he has done a lot of FE research.
sideoilerfe
Interesting. My "ribbed" block is out of my '72 Camper Special so what Dave says makes sense to me.
