A smelly situation
Bumpside70
A smelly situation
Post by Bumpside70 »
I was driving my truck home this afternoon and noticed a smell like rotten eggs was coming into the cab. I opened my hood when I got home and the smell was really strong under the hood. Any ideas as to what this could be? Thanks for any suggestions.
kaptnkaos
Re: A smelly situation
Post by kaptnkaos »
The rotten egg smell, is usually the battery being over charged and it's cookin' the battery acid
towtruckerfour
Post by towtruckerfour »
That was my thought. Have your battery tested ? Are the sides of the battery bulging at all? If so, the battery is sulfating inside.
Troy
Why is it that the trucks are always the best running vehicles in the family?
Ford means "found on road daily"
70 F100 Custom-352 w/68 Highboy 4x4 frame. My play/project truck
70 F250 Explorer-390/C6 auto. My work truck
04 Mitsubishi montero-family car
Bumpside70
Yeah I checked my battery before I left for work and thats where the smell is coming from. I saw where some of the acid is coming out. I bought the battery brand new in early August and this is the first time its done this. What would cause it to over charge?
NM5K
Post by NM5K »
Bad voltage regulator most of the time.
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
kaptnkaos
Post by kaptnkaos »
:yt:
Most likely the points in the voltage regulator are stuck and it is failing to cycle ... so it charges at full rate all the time.
I've seen giving one a good whack fix it, but it's best to just replace it... they arn't very expensive.
KaptnKA 8) S
Bumpside70
Thanks fellas for your advice. I've had the worst luck with voltage regulators. I've lost count of how many I've replaced on this truck since early 2006. Surely its not normal to go through this many of them. What could cause one to go bad so many different times?
brandon.k
Post by brandon.k »
I had the same thing happen a long time ago. On mine it turned out to be the rubber block on the back of the alt, had worn through where the two wires come out and they were touching. It would over charge when running and drain the batt. when parked for a little while.
kaptnkaos
Post by kaptnkaos »
The alternator could cause it.
I had the same regulator on my truck for 20 years.. through about 3 different alternators.
I put in a new one about a year ago when I put in the new alternator... I'm not sure if it is the alternator or regualtor actin' up now, but I've had problems with low charging output.
KaptnKA 8) S
the chinese are introducing new ways of making money. or is it old way are being reintroduced.
BRUTUS_T_HOG
Post by BRUTUS_T_HOG »
is that the new furby?
ASE Certified Technician
torquemonger
Post by torquemonger »
watch if there is a rotton egg smell H2S gas smells like that in low concentrations its a poisonous gas so don't go sticking your nose in close cause it can be deadly in higher concentrations.
67 mercury 100 352v8
2003 mustang gt 4.6L v8
grease,motors,and octane!!!
