lower doorskins replace - in the driveway
- jzjames
Well this was one of my projects for this summer, repairing the rusted out corners on the doors. Heres how it went.
I was going to fit the doorskin repair panels myself and take it to a welder for the welding? Well nothing is easy nowadays/ "project too small", "I'll do the whole job for around $700", etc..
So I decided to <do it myself> once again and figure out how to improvise.
I decided I could do it using autobody adhesive just across the top overlap of the doorskin panel, and crimp over the other 3 sides using...roofing tar.
Heres the project:
initially I was just going to weld in patches in the corners, thats why the rusted corners are cut out. I decided to do the whole bottom doorskins. Took my 4 inch grinder with metal cutting wheel to do all the cutting. Decided I would butt the metal on the two top corners so it would be flush, and overlap the top of the doorskin using the panel adhesive. Heres the cutting and fitting setup:
I got the doorskin bottoms from BOP for around $25/apiece. They were ok, Chinese made around 18 guage metal, but were rough and I wanted the exact width of the original door,so it was trimmed carefully. Then my plan was to dump in some asphalt-based roofing tar (from DAP) into the bottom fold, and the two vertical folded sides, and crimp those folded metal parts onto the door's inner frame. The panel adhesive would be used on the top overlap.
Here it is attached, the bottom and sides crimped over, just using vicegrips, (set just right!), and the top overlapped using the adhesive with pop rivets for clamping pressure.
The pop rivets were later grinded off after the adhesive was dry, and pushed through to leave the holes which were filled with the skim coat of bondo. (Indent the holes somewhat for bondo to cling, and on the inside of the door, smear tar over the bondo sqeeze-through). Here is the repair skimmed with bondo, sanded out and primed (Rustoleum Auto primer).
And of course since my truck is a rattlecan spray job, I am able to spray it to match very easily
Driveway doorskin bottoms. I did both sides.
Heres the project:
- flyboy2610
Re: lower doorskins replace - in the driveway
Nice job!
- kaptnkaos
Very nice Job JZ... they look mint KaptnKA S
Those turned out really good. Nice job
Troy
Why is it that the trucks are always the best running vehicles in the family?
Ford means "found on road daily"
70 F100 Custom-352 w/68 Highboy 4x4 frame. My play/project truck
70 F250 Explorer-390/C6 auto. My work truck
04 Mitsubishi montero-family car
- jzjames
Thanks, Im happy with the result. I dont think they will need to be done for a while.
One of the deals was to butt the top corners of the replacement panel. This allowed the doorskins to look flush overall. I actually used JB Weld to cover those side joints as that stuff is waterproof, and used regular bondo to skim over the overlap portion. On the inside of the door I covered critical areas with asphalt based tar to keep out moisture completely. There may be a hairline crack show up, but whocares. It will be something manageable instead of bubbling rust. I would be surprised if this repair doesnt last a long time.
- marvin2
Good job...not only do you save the money by doing it yourself, but you gain a lot of pride in knowing that you did it on your own. Looks great man.
- FoMoCo
Am I watching TRUCKS on the Power block? One frame there's a hole, the next frame it looks new? Nice job. You made it look super easy.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- 68FORDJBM
I got the doorskin bottoms from BOP for around $25/apiece. Driveway doorskin bottoms. I did both sides.[/quote]
Can you eleborate on where you got the doorskins? I'd like to do this exact job on my truck this spring. Until I can replace the doors
Thanks,
Thanks,
- HIO Silver
Can you eleborate on where you got the doorskins? I'd like to do this exact job on my truck this spring. Until I can replace the doors68FORDJBM wrote:I got the doorskin bottoms from BOP for around $25/apiece. Driveway doorskin bottoms. I did both sides.
Thanks,[/quote]
Unless I am mistaken, BOP is supposed to be "BOTP".. Blue Oval Truck Parts.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- 68FORDJBM
Thanks for the clarification
- ximy
- jthulan
Looks great, and you can say you completely did it yourself! WTG
1971 F100 Custom, 119,xxx miles
1984 Chevy Silverado, 437,xxx miles, original owner
1976 Ford Ranchero GT, 130,xxx miles
2015 Volvo XC60R, 60,xxx miles, daily
- abyars111
great job! thanks for sharing
Anthony
1970 F250 Crew Cab 2wd 390/2v short bed
2004 Eddie Bauer Expedition
1955 Chevy 210 4dr Sedan
- 68FORDJBM
Okay, I got my skins, the door removed, and the rusty pannel cut out. It all went much easier than I thought - like 1 hr. Now, is it easier to attach the skin along the cut or crimp the edges around the bottom? I have a welder but thout I'd start with pop rivets to keep it in place
- 68FORDJBM
Some pics of my lower skin driveway job: easier
On the second door I welded some tab/shelves for spot welding the skins on
[URL=http://s778.photobucket.com/user/m ... .jpg[/img][/url]n
Multiple spot welds to attach:
If I were to do this again I'd spend the extra money on full skins. Would have saved time and filler
