Stuff I put in it.
![Image](http://i820.photobucket.com/albums/zz130/fordman7072/6.jpg)
First 3 cly
![Image](http://i820.photobucket.com/albums/zz130/fordman7072/DSCF0239.jpg)
Last 3 cly
![Image](http://i820.photobucket.com/albums/zz130/fordman7072/DSCF0240.jpg)
All of them
![Image](http://i820.photobucket.com/albums/zz130/fordman7072/DSCF0238.jpg)
Head
![Image](http://i820.photobucket.com/albums/zz130/fordman7072/DSCF0241.jpg)
Every thing looks ok to me so any ideas. I've tryed turning it by hand and with the impact and it wouldn't go any farther.
It shouldn't be that because the motor and trans have never been apart.70_F100 wrote:
By looking at this latest picture, it looks like it's an auto tranny. Since the engine hasn't turned since it was installed, I strongly suspect it's either a converter bolt or the converter wasn't seated correctly in the pump. Either of those would create the problem described here.
All of the pistons move and there is a little dirt on the top but not a whole lot. Its kinda smeered around becasue I wiped it all off with WD-40 before the picture.OldRedFord wrote: FordTruck do you notice any of the pistons not moving when you try to roll the engine over?
Is it just the pic or is there grit all over where the lifters are?
Say what?bjde0b wrote:I didn't read everything that has been written, but this is my two cents. Get some strong drain cleaner that will eat up aluminum and put it in. It will eat through your pistons leaving a nice clean block. I can't remember my brand of preference, but it is in crystals. I am too lazy to walk out in the garage and look at what I used.
Me and my dad thought about that but we couldn't see how that could have happend just from sitting but I'm thinking about going ahead and doing that because its got those carbor fiber gears on it now and I'd like to swap in some steel gears.70_F100 wrote:With the pan removed, you could also get the timing cover off very easily. It's possible you have a timing chain that's loose enough that it's getting ready to jump a tooth, a broken tooth that's wedged in the chain, or maybe something just worked its way in there. There's probably enough slack in the chain to warrant replacement, regardless of what you find.
