rookie mistake, new counsel
rileydog
Post by rileydog »
i have an all original F100 Custom just needing a little TLC. I was removing the carburator(1st time in my life) and twisted the fuel line that runs out of the front of the carburator to the fuel pump. I don't want braided line, would like to keep my truck original. Its a 302 2barrel manual transmission. Any advice about where to find a suitable replacement.?Thanks from a new member.
sacramento_ford
Re: rookie mistake, new counsel
Post by sacramento_ford »
pick n pull or national parts depot, also autozone or kragens has alot of old truck stuff.
sideoilerfe
Post by sideoilerfe »
it's just 5/16 fuel line .You can get it in bulk and bend it to your application. Use your old one as a template.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
m-mman
Post by m-mman »
:yt: Just remember that the 5/16 steel tubing needs to be bent with a tube bender.
Just one inexpensive example from Hrbor Freight.
http://www.harborfreight.com/cpi/ctaf/d ... umber=3755
You can get them anywhere. Various styles and prices.
The universal tube you buy will most likey need to be cut and flared also
http://www.harborfreight.com/cpi/ctaf/d ... umber=5969
Bending and cutting tubing is a skill. Like everything on our trucks, there is a learning curve, thats why they are a hobby. :wink:
A fuel line is a good place to start and get some practice.
1969 F-100 Custom Cab 302 T-85 Overdrive, 3.70 equalock & factory 16" wheels
DuckRyder
Post by DuckRyder »
While you can bend it from bulk, you can also buy exact reproductions from NPD, Inline Tube and several other suppliers in both regular and stainless steel.
suavematt
Post by suavematt »
NPD's a good source... I'd also order yourself a FREE LMC Truck catalog. They've got everything "stock/option" & a few other aftermarket goodies in there as well.
Later.
~ 8) Suave'
Name's Matt. I'm a southern' Boy with a love for the Lord & Carb'd Ford V8's hahaha... Anything else you wanna know... Ask ; )
1979 F-100 Super-Cab/Long-Bed Work-Truck [300 I6, C4, Ford 9" Rear]
1993 Ford Ranger, single-cab short-bed [2.3L 4-banger, 5spd trans, 7.5 rear... Full-time Convertable ; ) ]
1972 Ford Mustang [351-Cleve' (being built, still workin' on it), C4 auto, Ford 9" Rear]
