odd tapping
odd tapping
well i got her runnin but im hearing an odd tapping from the passenger side. it sounds like rockers tapping valve cover but its not cuz i checked. its erratic, not constant and don't do it till engine warms up? any ideas?
Re: odd tapping
its probably in the valve train somewhere. it just gets warmed up and gets loose enough to tap. what and where i dont know.
- Camper Special Ed
Re: odd tapping
I had a 460 in my 70' camper special. It did the samething, I finally tore the motor down to find the # 7 piston ring groves where broken.
I hope thats not the case with your truck
1970 Ford F-250 Camper Special. 351 Clevland V8
1971 Ford F-100 Stepside Pre Runner. 460 CI V8
1962 Ford F-250 Factory Flatbed. 292 CI V8
1989 Ford F-350 Dually. 460 FI CI
1968 Dodge Charger (General Lee) 318 V8
1959 GMC 101 Stepside. 350 V8
1957 GMC 100 Stepside. ( in a Million peices)
1959 Chevy Panel. 350 CI V8
Re: odd tapping
one time i had that tapping, i replaced mechanical fuel pump it went away
- zakt
Re: odd tapping
same thing going on, on my 460 EFI (thought maybe a lifter?) I have drove it for years like that
but seems to be getting worse ![Very Happy :D](./images/smilies/icon_biggrin.gif)
1972 Ford F350 crewcab
![Image](http://www.fordification.com/galleries/albums/userpics/10045/350emblem~1.jpg)
Re: odd tapping
What kind of engine is it? If it is an FE did you have the rocker shafts off? The rocker shafts on an FE have one special bolt that has to go in a specific hole or the rockers do not get oiled properly. It is a pretty common mistake. Edcjroddam wrote:well i got her runnin but im hearing an odd tapping from the passenger side. it sounds like rockers tapping valve cover but its not cuz i checked. its erratic, not constant and don't do it till engine warms up? any ideas?
- t-waits
Re: odd tapping
Some shops have stethoscopes with long needle like ends used for isolating things of this nature. If it is determined not to be coming from the valve train area another thing could be a wrist pin issue as I have seen this before on an FE.
TW
TW
- Sam I Am
Re: odd tapping
A standard stethoscope and a yardstick also works pretty good for that.
