exhaust hanger fuel tank bracket
i have a 71 f250 camper special for a parts truck. it has the aux fuel tank. on the front bracket that holds the front strap. there is a second bracket that goes to the passenger side. i think it is some sort of muffler hanger bracket or exhaust bracket of some sort. it looks more like a fuel tank bracket of some sort. i forgot to take any pics of it. has anyone seen these brackets? is it a exhaust bracket or is it something from the fuel tank that was moved to hold the exhaust pipe up?
- Dragon
Re: exhaust hanger fuel tank bracket
On the truck you have both exhaust pipes run down the passenger side to the back one above the other with a cross from the drivers side just under the tranny front end. The Gas tank is on the driver's side.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
My Gallery
Spark test
- sideoilerfe
The trucks came with single exhaust from the factory.Dragon wrote:On the truck you have both exhaust pipes run down the passenger side to the back one above the other with a cross from the drivers side just under the tranny front end. The Gas tank is on the driver's side.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- Dragon
You are right until you get into the 500 and up size trucks. I used my truck as an example which has iron manifolds and the pipe crosses to the passenger side and is duals.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
- Dragon
Mine has that.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
that is wierd. i thought it was part of the tank strapping on a f250. didnt the f250 have no skid plate? and only hanger brackets for the aux tank?
- flyboy2610
That's what I plan to do with my F250CS. It has the drivers side auxiliary tank which I want to retain.Dragon wrote:On the truck you have both exhaust pipes run down the passenger side to the back one above the other with a cross from the drivers side just under the tranny front end. The Gas tank is on the driver's side.
- Dragon
My truck had no skid plate and the book does not show a shield in 71 for an F series. Oh fordman mine has that as a tank support were you think it goes.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
I'll have to crawl under my 72 tommrrow and see if it has that. It seems like it has that but I thought it was like a driveshaft loop because I think it bolts to the bottom of the skid plate but I'll look tommrrow.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
ok i found it on this page. http://www.fordification.com/images/sch ... dplate.jpg it is part of a skid plate bracket. but htis one didnt have the skid plate. it hada front strap.and the rear bracket, strap or skid plate was missing. so i am hoping i can make this bracket work for the rear bracket. that junkyard keeps hauling off all the trucks out there. i will get it put on one way or another. or mayeb i have the strap left off of the 78 i parted out. that would be great if it worked.
Are you gonna need a skid plate or the brackets? If you can't find one up there I'm almost shure the junkyard down here has one. Its got either a 71 or 72 F250 I don't think its a CS but its got the dual tanks.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
This is all good info, I was considering installing the aux tank and using as a main so I could take the in cab tank out
i am pretty sure i have everything i need for this now. i just need to dig in the part trailer to find the extra straps i saved from the 78. its going to be awhile before i am able to install it though. i will start a project thread when i do it. i did think it was kind of wierd that the tank has two strapping methods on it than is suppose to be on it. by the diagrams it should only have either a skid plate or just the straps alone. but not both.
