hey yall!
i have my 1792 ford, at a stock ride height, it is a 2wd but I have a 3" lift I was given and I want to install it, but I was given springs from a 4x4 front suspension (and blocks in the back)...will it all bolt up? and if so..will the longet springs throw off the camber of my front tires because i have the twin I beam?
thanks!
PLEASE HELP!
PLEASE HELP!
72 ford power
1972 ford F250 RANGER XLT! D.S.O.!, 3/4 ton "heavy" Camper special, with stock A/C, a 4 speed NP435 tranny and the stock (its an H code) big block 390 with a Holly 600 carb, my rear end is a dayna 60 with a 7 stack and an overload, all resting on top the stock rims, hub caps, and yes...stock tires, they are bious-plys!
- SteveC
Re: PLEASE HELP!
more than likely yes messing with spring length will mess your camber on a twin i beam set up... there was a post on here how to lift a 2 wheel drive but i can find it at the molment
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
Re: PLEASE HELP!
this longest spring you have. is it a aftermarket spring? is it a coil spring for the front? if so it goes on the passenger side. the aftermarket springs for the passenger side sometimes are longer instead of a stronger size around coil to make up for the offset engine weight. the camber can be reset if it is off by cold bending the i beams on the truck.
- SteveC
Re: PLEASE HELP!
1967 f-100 4x4
1967 f-100 4x4
