That was my concern.... wanted to see if anyone else had that same thought without planting the seed.averagef250 wrote:What he's saying is he addressed the KDP with his own method. You can see the stamp marks he's made on the timing cover.
I would grind a washer before peening the case myself if I was worried about it. The vibrations that work that pin loose from the cast iron engine block will work it through the much softer aluminum just the same.
I should have taken the time to make some measurements on the pin itself. It looks like this gear housing wasn't machined completely through that dowel pin bore. I was thinking that I didn't even need to pin it.
Anyone know the diameter of that dowel pin?
Thanks!
