double front shocks and 1980 f250 springs that lift is 3" this is just a pic to show how far down it can go the front shocks are off an 06 ford FX4
the link is in my sig
Steve
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
yes they have the stud up top and the eye hole no the bottom they are rancho's. they were too long for the stock mounts:D. they are the stock shocks off a 2005 f250 Fx4 i got them off ebay
Steve
are they the rancho 5000? I have a 4" lift on my 67 f100 and Im trying to get the correct part number for the front shocks. I have the stud up top and eyelet on bottom, but the ones I got from rancho that were "suppose" to fit my truck had the stud on top and bottom. How long are thoes shocks compressed and fully extended if you know? and what is the shock part number? My shock mounts in front are 18" apart after my 4" lift.
do you have the rollcage becuase you jump your truck?
i dont know what the serise is it just says rancho on them the front shocks are 16" to 24". the set in the link is like the set that i bought but the rear are huge so look at my gallery to see how i mounted those if you want to buy that set.
oh yeah. no i dont jump it but i had to cut the old roof off because it was completely rusted out and wanted to make that part stronger just in case i roll it like what happened to AmericanMuscle67 and to mount my seats and 4 point harnesses to. + i think it looks pretty cool
