swapping 6 cyc engine for a v8..will it fit
- thebannister8
i have a 6 cyc 240 with a 3 speed ( light duty trans code c )..can i swap a v8 in there without changing the trans...would i need special mounting for a v8...thanks ![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
Re: swapping 6 cyc engine for a v8..will it fit
no they are different transmission bellhousing patterns. the 6 cyl is a small block pattern and the fe is another pattern. as well as the 429 460 and 351m are a differnt pattern. i think ford used five different patterns for thier engines. i have named 3. i forget the other patterns. 1 more could maybe might be the Y block pattern.
