what cam size might this be..video.. 67 f100 390
thebannister8
Post by thebannister8 »
this is off of youtube...the guy has a 390 hipo? and it's been awhile since i've built a v8...cams used to be called 1 stage , 2 stage..etc...and also an rv cam...that was the lingo around my area anyhow...can you v8 buffs identify roughly the stage of this cam....i want to build a v8 and i like that cam ..thanks....btw...an extra note...i laughed when he closed the door and it made the same solid metal sound mine does...man i love that :thup:
http://www.youtube.com/watch?v=bHVyh0oc4tE
here's the guy running it..runs an 11plus 1/4 mile
http://www.youtube.com/watch?v=7k931izd ... re=related
Happy_Camper
Re: what cam size might this be..video.. 67 f100 390
Post by Happy_Camper »
Man, I remember those days fondly!
Everyone either had a 3/4 race cam or the real "cool kids" had a full race cam. Those of us who had to work for a living where lucky to have an RV cam. I think that truck just needed the choke set correctly.
Now and then someone came to school with a cam that sounded similar to this truck. If I remember right we called it a "hit-n-miss" cam. Very exotic.
Here's a video of one in action. Now you'll have to use a bit of imagination to think of this in your bump, but yeah, it's way cool. :thup:
http://www.youtube.com/watch?v=iLAic2uVlWo :D
***** Edit: Because after thinking a bit, I realized this post may not be taken in the light hearted fun way it was meant. And for that I sincerely apologize. It was meant for fun, and I really do remember the good old days when I used those same monikers of 3/4 and full race cams. That sound can be fairly well replicated in a well tuned engine by using long tube headers, a slightly more open (say 2.5") exhaust, and a low idle, even with a somewhat mild cam. I met a guy who is running this cam in his 390 http://store.summitracing.com/partdetai ... toview=sku, with mildly ported heads, a Edelbrock performer intake, and his idle set to about 650. Sounds a lot like the truck in the video only a bit more crisp, because of the carb settings. When he took off, it sure seemed to put down some killer grunt. He was pulling a trailer full of wood, and from almost a dead stop, up the on ramp (about 1/10 mile) he merged with the speed of traffic. He turned about every head in the whole gas station :)
I don't know much about big blocks (I've always built small blocks), but there seems to be some very good threads here on engine builds. And there is a good "Exhaust sounds" thread as well. ****** end of edit
BTW: that was an 1/8th mile track. Very cool to see two trucks lined up together. The old white truck was hooked up out of the hole, but ole blue might have been gaining at the end, or maybe it was the camera angle. In any case, that white truck is very nice!
Scott
1972 F250 Explorer C/S, 390-2V, Dual exhaust, C6, Goose neck ball in bed
New and improved with Tilt Wheel, Intermittent Wipers, 2005 Bench seat and 5th wheel camper!...
Life is *very* good!
My427stang
Post by My427stang »
Thats not that much cam, I'd guess at the most a 280H from Comp. Sounds like he just has it cold and idled way down.
Not that its a bad cam, that's what I run in my truck, but the lope is due to loud exhaust, cold temp and a decent cam.
1967AceStroker
Post by 1967AceStroker »
He calls his motor a hipo 390, whats that, hi-performance?
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
FreakysFords
Post by FreakysFords »
Happy_Camper wrote:Man, I remember those days fondly!
Ahhhhhhhh the 3/4 cam. Back when we had no idea what lift, duration, overlap or anything but that tail kickin sound that meant those of us who had to pay for AND driver our vehicles might as well stay parked till the show turned to go. :)
I do miss it and now that I can finally afford a cam, I can't walk into my locally owned independent parts store (cause it / they don't exist in our backwood town anymore) and tell the grease monkey behind the counter that I want a brand new 3/4 cam for my ______ engine and maybe a new set of lifters if they have'em in stock and I can afford'em.
Darlin 69 Ranger 390 4v, PS, DS II, disc front, 3G alternator, 67 mirror.
thebannister8
i enjoyed your humor and thought it was cool....seems my high school rankings of cool depended on very similar factors to yours....i had an rv cam
:woohoo:
thanks for the info everyone...and i thought that track looked a tad short :hmm:
DuckRyder
Post by DuckRyder »
I agree it doesn't sound like that wicked of a cam, I had a Crane "801" (343801/2) in my 360 for a while that sounded like that is idled at the factory specification of 650 in drive. To me it really doesn't sound that good because it is idled so low. I'm guessing since the blue truck was taken by the same person you could probably call the shop that he has the phone number plastered across the back window and just ask. (explain so it doesn't sound too stalker like) or perhaps you could e-mail from youtube? Invite em both to join up while you are at it.
thebannister8
great ideas... thanks :fr:
