Those of you with a 302?
Well I have a 302, and it runs hot. Normally 1/2-3/4, my dad said it should run about a 1/4, what does your guys run?
Re: Those of you with a 302?
Not sure on factory gauge what mine runs. Have an aftermarket gauge and it runs about 190. Not sure if that helps or not.
- Lar4t9r
I run both factory and aftermarket gauges. Factory 1/4...after market 160.JMcTurnan wrote:Well I have a 302, and it runs hot. Normally 1/2-3/4, my dad said it should run about a 1/4, what does your guys run?
Laurence (Proud owner of 1969 Ford F-100 and 1970 GTO)
![Image](http://i461.photobucket.com/albums/qq339/Lar4t9r/1969_Ford_1-1.jpg)
![Image](http://i461.photobucket.com/albums/qq339/Lar4t9r/MrHorsepower.jpg)
![Image](http://i461.photobucket.com/albums/qq339/Lar4t9r/70GTO_2-1-1.jpg)
the ford thermostat should be a 192. but you could go down to a 180 degree thermostat.
- HillbillyDelux
dont know about quarters but mine hangs out around the m on the factory gauge and ive got aluminum rad and elec. fan
2000 Ford Ranger 4x4 "DD"
2003 Cobra
"If it ain't broke fix it til it is"
2003 Cobra
- drytoast
My temp gauge doesn't even move. Hmmmmm maybe I should get that fixed if some warm weather ever gets here. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Life is hard; its harder if your STUPID. John Wayne
1972 Ford F-100 Explorer 302 C4 automatic
2005 Chrysler T&C Limited
1996 Honda Accord LX 238,000 miles and counting
So mine is running hot then, what do you think problem could be, just redid manifold gaskets, only other thing i could think of is head.
- Joshpow
Mine won't even get into the low normal range. It runs around 175 at the warmest unless I sit in traffic. I never have good heat during the cold months for that reason, but it sure is nice when it's hot outside to not worry about overheating.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
The 302 in my 70 runs about 160 to 180 usually,but I haven't driven it enough to know what it'll run for shure.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
Might want to check and make sure thermostat is working correctly
- papabug71
Mine runs between 180-190 all day long. I know a guy here in town that had a 302 in his truck. He rebuilt it, but when he did, he had it bored out to no end. .060+ That thing would run hot in a blizzard.
Has your 302 ever been bored all the way out???
Your first upgrade should be a good set of under dash gauges. That way you can see exactly how hot its running. That 1/2 to 3/4 stuff is for the birds.....
![Image](http://i42.photobucket.com/albums/e340/bigmacdak/papabug71sig2-1.jpg)
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
- Lar4t9r
I added the after market gauges 'cause I didn't trust the stock gauge. I was a little concerned with the 160 temp thinking it was a little low, but it runs good and never rises much even in stop and go traffic. Ifigure rather than changing the thermostat so it runs hotter, I'll just keep an eye on it and see how it goes.fordman wrote:the ford thermostat should be a 192. but you could go down to a 180 degree thermostat.
Now as far as what to do for running hot, I had a SS 396 a few years ago that was doing that...every time I stopped it would puke anti-freeze. I thought it was a bad thermostat, changed it but no improvement. Then a mechanic friend suggested having the radiator cored and that solved my problem. Just a thought.
Yea I am using the dash one, I could try to pick up another, its never been bored all the way out, and just replaced thermostat.
- thebannister8
right manifold gaskets...not blocking any passages ![Confused :?](./images/smilies/icon_confused.gif)
...whenever i get a new thermostat...i always boil it to make sure the thing works..
you may also want to run it without the thermostat to see if it will cool down more.....
fan clutch ok ( if you have a fan clutch )
radiator full of gunk
hoses crimped
sending unit correct![Confused :?](./images/smilies/icon_confused.gif)
hoses crimped
Everything is good, except I dont have original fan, so no clutch.
