Passing gear to carb
JMcTurnan
Post by JMcTurnan »
How do I hook up a passing gear to carb, so my truck has no power in speeding up fast. And my dad says the trannys passing gear isnt hooked up, i dont know jack about trannys, how do i hook it up?
Re: Passing gear to carb
the rod hooks to the carb and the trans lever. each place where it hooks up is held on by E clips. i don't have any pics but the empty studs will tell you where it hooks up.
Joshpow
Post by Joshpow »
:yt: It is a kickdown rod that connects the passing gear lever to the carb. Mine is missing too, but my 302 is strong enough to not miss it much. It ain't the most powerful, but it can do the job fine!
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
This is what it looks like installed:
...and looks like this, depending on your engine/tranny combo. This particular one is for a 302/C4:
JMcTurnan
Post by JMcTurnan »
See and mine seems like it put puts once in a while, up hills, and when I put it to the floor. So do you think thats it? But I have a 351w im about to put in in the next month, pulling it out of my boat and putting it in, should bolt right up, and will need a new water pump.
usually the onmyl time you need that rod to kick in is going up hills or passing someone.
JMcTurnan
Post by JMcTurnan »
Which exactly sounds like it, i guess untill I get the 351 in if im going up big hill I can down shift to 2nd.
Rusty67
Post by Rusty67 »
The old Ford trans didn't need this linkage hooked up like the newer AODs and AODEs do. They simply tell the trans to kick down to a lower gear when a certain amount of throttle is applied and there is a ceratin amount of pressure running through the trans. Nothing wrong with manually shifting the car into 2nd.
Just a side note, if you ever put an AOD type trans in, the TV linkage MUST be hooked up correctly before even driving the car at all. Even low miles on an improper TV adjustment can royally screw up a brand new trans.
JMcTurnan
Post by JMcTurnan »
Nah im gonna stick with the old c4's lol
Rusty67
Post by Rusty67 »
Good choice there man, the AOD/AODE trannys need a lot of upgrades to handle any heavy duty work.
