Your truck looks sick as is but yeah those are torque thrusts on the dent side.td wrote:sweeeeeet!!!!!!! ya just gotta love that phantom grill! i wonder what insert they started with? might have been one for a 81-87 c-10?
thanks for the pics marz! i'll save them.
i also love the grey coys!! i think i'd trade straight across for a set right now!!
Edit...... you know after going back and looking at it again, i don't believe those are coys. the center caps look like torque thrusts. man i should have had the guts to go grey with mine
bumps with lowered altitude!! (lots of great custom bumps!!)
- marz68
Re: bumps with lowerd altitude!! (pics please)
i had a set of those a wile back but i sold them kinda wish i had them back.
they were 17x8's i yhought that they looked funny with the trim on pearl,kinda too mutch shinny or something
just didnt look right.i still looking for the right wheel.
td did you go to a special site or somthing to get your wheels custom ordered?
- td
Brad,427blackpearl wrote: td did you go to a special site or somthing to get your wheels custom ordered?
i looked up a phone number for American Racing in CAL, and when i called them on that number they gave me another # to their custom shop. i wished i'd keep up with them for future reference but i didn't
a big set of grey center 20's would look absolutely killer on pearls black paint!!!!!
What type of link setup are you planning on using?
I would reccomend redoing the upper shock mount brackets, they should be in the same position as the bottom so they wont bind. My buddy bought a truck that had the shocks like that and the mount was tore off at the frame.
Dan
'69 F350 Crew Cab
'69 F350 Crew Cab
- td
Mike,mike68merc wrote:[ I got my 18" x 8"s, & 20" x 10"s with tires, center caps, valve stems, lug nuts, mounted & balanced, for around $1500.00 (including delivery!)
man those coys are a good buy for the $ ! i have a freind that called and priced a set of grey center 22's & 20's staggard for $1850 with tires to his door. you just can't beat that!!
mike did you use a diffrent lug pattern? i kinda like the c-57's in gun metal but there only in 5'' lug pattern
also hows your truck workin out? any new pix?
- td
Brad,427blackpearl wrote:mike did you use a diffrent lug pattern? i kinda like the c-57's in gun metal but there only in 5'' lug pattern
if i was you i'd call them and inquire about the 5x5.5 bolt circle, i notice none of their products are listed in it. i'm guessing they'll make what you want but i could be wrong. if you find out let me know just to cure my curiosity
Oyea i looked at the C-57's that a great looking wheel!! sort of nostalgic looking hu?
- mike68merc
Yes I did. As you all have discussed, there is a pretty limited selection of wheels made for the 5x5.5 bolt pattern, & then when you finally find a wheel that'll bolt up, you see how few offsets are available!!! Also, my Mustang II IFS kit came standard with 5x4.5. The hubs are super easy to re-drill, & I knew I had to have them machined to accept the rear disks anyway. 5x4.5 seems to be fords most common hub size (for full size vehicles), & it's been used for a long time. So I didn't fight it, & went with the 5x4.5. There's GAZILLIONS of wheel options, & offsets available for 5x4.5, so no special ordering is required.427blackpearl wrote:mike did you use a diffrent lug pattern? i kinda like the c-57's in gun metal but there only in 5'' lug pattern
[img]<a%20href="http://s399.photobucket.com/albums/pp78 ... 5x4.5"></a>[/img]
This is the re-drilled rear hub.
By the way, Tim asked if they could be ordered in 5x5.5... Looking at the wheels, It doesn't look like there's enough meat left on the Flange to be drilled out that big...But I'm curious to see what the answer will be.
MIKE
- td
here's a cool lowered bump. this is a pic i took a few years ago at the RodRun in pigeon forge TN. it had FE series motor and 4-link with coil over rear suspension. very sweet truck !! i looked at it until my eyes hurt notice the nice job done on the wheel wells in the bed.
- dantheman71
That is a sweet looking truck td. My only question is, why would he take the time to shave the door handles and not take the time to put in an underbed tank? It just seems like a waste of time to do one and not the other...
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
Check out my NEW build thread: http://www.fordification.com/forum/view ... 93#p641993
2002 Ford F-150
- td
i totally agree! but everyone's different hu?dantheman71 wrote:That is a sweet looking truck td. My only question is, why would he take the time to shave the door handles and not take the time to put in an underbed tank? It just seems like a waste of time to do one and not the other...
- dantheman71
That is true. I am glad you posted it, I plan to go with a one color paint job with shaved handles (AND KEYHOLES) and no gas filler. I think it will look good when I am done. Now if only I could pick a color.
1972 Ford F-100
2002 Ford F-150
2002 Ford F-150
- td
ya know i just noticed this one has the vet windows shaved, Hmmm? i don't even think i noticed it when i took the pic in 04.
- dantheman71
Good eye, I missed that too!! I actually like that look, if it were an original truck then keep the vent windows but if you are going lowered and custom I think it looks good without them. Is there a kit you can get to do that? Or is it all custom work?
1972 Ford F-100
2002 Ford F-150
2002 Ford F-150
- td
its a cool mod for extreme customs, and if there was a affordable kit offered for our trucks i'd jump on it. unfortunately there's not one, and what i've read here on the subject it requires a upper door hinge modification. if you did a search on vent windows here, you'd find some discussion on the topic here somewheredantheman71 wrote:Good eye, I missed that too!! I actually like that look, if it were an original truck then keep the vent windows but if you are going lowered and custom I think it looks good without them. Is there a kit you can get to do that? Or is it all custom work?
