1971 f250 DESERT truck- 10/24 race prep
- ares360
Re: 1971 f250 DESERT truck- offroading update! 12/28
how much did you get your 429 for?
Kane
1971 Ford F250 4x2, no engine.....what am I going to do?
- 1971ford
free-hundred dollarsares360 wrote:how much did you get your 429 for?
found a truck on Craigslist, decided to check it out and build it as the offraod truck. turned out the truck was a rusted away piece of scrap so we bought it for $600. pulled the 429, scrapped the truck for $400. kept the new aluminum diamond-plate toolbox, sold all good parts. so it evened out as getting it for free
-Ryan
- ares360
that works.
Kane
- 1971ford
video. you can hear that beautiful tranny slip even
http://www.youtube.com/watch?v=cbXkp8kO ... annel_page
tranny slip:
http://www.youtube.com/watch?v=57cJXAVXD2E
casual drive:
http://www.youtube.com/watch?v=DRU3fo4Z ... re=channel
quick exhaust:
http://www.youtube.com/watch?v=mKoVhIfHTQo
tranny slip:
casual drive:
quick exhaust:
-Ryan
- aramil
hey that pic doesnt look like sand, i thaught this was a pre-runner
, are you gunna chop off the rear of the frame and build a tube frame with a 4 link or leave the frame and stick with the leaf springs? do you have any sorta traction bar to keep the power of that beast from warping the leafs?
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
- 19674x4
i feel sorry for the camera man. aka your dad. musta got soaked.
My Photo Album
- 1971ford
were going to keep the full stock frame since we will be using Deaver leaf springs. no leaf spring setup is as good as a 4 link but for our budget and simplicity we will be using leaves. the Deavers should soak up bumps just fine, its what a majority of the prerunners use.aramil wrote:hey that pic doesnt look like sand, i thaught this was a pre-runner, are you gunna chop off the rear of the frame and build a tube frame with a 4 link or leave the frame and stick with the leaf springs? do you have any sorta traction bar to keep the power of that beast from warping the leafs?
right now its all stock with just 2 of the bottom leaves gone. its still as stiff as a rock, but it is a little better for the meantime. very little of the engines power gets to the ground, mainly because the tires are bald, and on dirt.
nope he stayed dry. well except for when he rolled his window down just before a puddle for some reason19674x4 wrote:i feel sorry for the camera man. aka your dad. musta got soaked.
-Ryan
- robroy
Hey Ryan, where's that road? I'm over in Palo Alto (just south of San Francisco) but it's always good to know about areas like that within driving distance.
-Robroy
-Robroy
- 1971ford
the trail is in Latrobe, which is El Dorado county i think. its right off of Latrobe road, where Scott road t's into it. there is a bunch of fun whoop-dee-doo roads on the way too, and the drive around that area is nice
-Ryan
- 1971ford
since we are going to be starting the cage soon, i decided to clear up space in the cab so we have room to work. i pulled the in-cab tank and installed a 32 gallon fuel cell in the bed. no im just kidding, i wish
instead i just mounted it right up the the bed behind the cab and ran 6 feet of fuel line over there. the truck didnt even stall when it was running off the gas in the carb and the fuel pump was sucking fuel through all that line.
here is the masterpiece. notice the 2x4's on the bottom
i'll probably make some mounts at the welding shop to support the bottom since we plan on going back to that trail.
yay no more in-cab.
fuel lline was routed on a crossmember. check out the muffler mount
thats the nut there at the very bottom of the mount, hanging by a thread.
oh and for the most fun while doing this, make sure the tank is topped off with gas so it weighs too much for me to handle, and it sloshes out the cap onto you when pulling it. and its alot more fun without any help too
yay no more in-cab.
-Ryan
- robroy
Does this mean you relocated the fuel tank with the engine running? I thought they only did stuff like that in The A Team.1971ford wrote:the truck didnt even stall when it was running off the gas in the carb and the fuel pump was sucking fuel through all that line.
-Robroy
- 1971ford
when i turned the truck on after i finished relocating the tank it didnt die when it had to pull gas from the tank through all that line.
-Ryan
- 67 ford f100s rule
your 429 is lookin good. Your definetly keepin up good work. when you got it done it will be good to see you get out and have fun.(maybe win something too)
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
- METALMASTER
- 1971ford
i got my shifter and linkage kit
and made the skid plate...
and went back to get dirty again
tada all clean
ive also decided to build the old 360 that came out of this truck into a fast 390. we went and picked up a 390 crank for starts
next weekend i want to start the cage
tada all clean
-Ryan
