Cylinder Heads
Cylinder Heads
Can I use 390 heads on a 360? Do I have to change other components or with they work as they are? Also, what can a 360 be bored to? And by that I mean, what cid can I achieve by boring the block?
Re: Cylinder Heads
the heads are the same they will fit. i'll leave the boring stuff to someone else.
Re: Cylinder Heads
Heads will fit.
Without sonic checking .30 over is about the limit on a 360 block, however 360/390/410 blocks are identical and you can obtain those displacements using factory rotating aseemblies. Larger displacements are possible using aftermarket parts.
- willowbilly3
Re: Cylinder Heads
I read once an FE with no core shift could be bored .090. It was in an article about sonic testing in some Ford specific magazine.
- FORD428CJ
Re: Cylinder Heads
What block do you have? If its a D3 or a D4, you will be able to go bigger then .030 over.....JMHO
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
64 Falcon X-Ram 428
67 Stang 351 C/J
- averagef250
Re: Cylinder Heads
Never heard of any problems going .060" with a D3 or D4 block.
Re: Cylinder Heads
The MCC castings are said to be a bit better quality, still if I had any intentions of leaning on it very hard I would sonic check it before going over .30. Particularly with my luck, "should" and "will" are not the same thing.
- willowbilly3
Re: Cylinder Heads
I agree. Why not spend a little extra and know for sure. On a street engine it isn't as critical but for any kind of performance or severe duty I would sonic test. I also remember in that article that the Cleveland blocks were really thin. Some they tested with stock bore did not have enough wall thickness on the thrust side to use for a build. I can't remember the numbers but even a perfect Cleveland couldn't go over .030 by their standards. As mentioned, a tested 390 with no core shift could go .090 and a 460 as far as .125.DuckRyder wrote:The MCC castings are said to be a bit better quality, still if I had any intentions of leaning on it very hard I would sonic check it before going over .30. Particularly with my luck, "should" and "will" are not the same thing.
