big vacuum hose comign from front of carb we plugged off. if im thinking right, its suppose to go to the pcv valve on the valve cover but we didnt have a long enough hose
i think what we'll do is get skinnier 33's and cut the fenders alot more.aramil wrote:thats gonna be one mean lookin truck when its all said and done, what size tires are on it now? if 33s are too big why not go with a good set of 31s?
yeah that was a long time agoBiggDogg wrote:Hey Ryan, did you guys ever install the flowmasters?
good idea but i think if i moved the SPEED-BUMP sticker under the bump then it wouldnt look right with the stripe suddenly ending. if i had of carried the strip on all the way to where the tailgate would be then it would be under the bump.aramil wrote:just trim a bit of the fenders off or find that company that makes the fiberglass fenders with the bulges up front, then you would have lotsa room to tuck those tires.
*flared-fenders.com is the source for the fiber glass ones i was talkin about, they might help with the front to rear weight transfer with that big block up front.
put the stickers under the bump line somewhere to bring some attention lower on the body and the top wont look so cluttered, and you need some shock hoops stickin out the hood nothin says prerunner like big coilovers and lotsa suspension flex
