Oil Filters
- peanutman
Oil Filters
I see comments from time to time on oil filters. What is the best brand filter and why. And what's the deal with Fram oil filters. I always thought they were good quality and thought there manufacturer made most of the store brand filters.
http://s533.photobucket.com/albums/ee33 ... e_Johnson/
1970 302,ps, ac, 3 speed o.d.
re: Oil Filters
http://knizefamily.net/minimopar/oilfilters/index.html
FWIW I ALWAYS use either a factory filter for the car or an OEM manufacturer. In a pinch I'll use a Mobil1 filter.
- rubiranch
re: Oil Filters
I have always preferred OE oil filters too, I use Motorcraft on my Fords, Mopar on the wife's Jeep and Honda filters in my ATV.
There might be better ones but you can bet there are a lot of crumbier ones.
re: Oil Filters
Am i missing the boat i thought fram was the best???? Remember pay me now or pay me later!!! Has thier quality gone down that much???? fill me in!!!!
lover of old fords
re: Oil Filters
I have seen 99$ oil filters from Wal-mart that are better then frams cut open. With frams you are just paying of the name. Also frams are good for leaving the gasket on the block. I have cut open a lot of filters. I use wix and Motorcraft.
Kyle
Kyle
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1969 f-250 390 CS,ranger, PS,PDB,AC
1968 F-350 360 PB
1968 f-250 360 PB
http://s222.photobucket.com/albums/dd207/truckguy_02/
- HH Henderson
re: Oil Filters
I had always used Fram until few weeks ago when I noticed my oil light would come on at an idle speed. Someone on this forum said to use Motorcraft which I did and now no problem.
"any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves Einstein
http://www.satisfaction.com/photobucket-login/
1968 Ford F100 360 cu (ole blue)
re: Oil Filters
When you put a new filter on, fill it up with oil. Let it soak in and keep
filling it till you put it on. A little bit of hassle, but it's worth the extra
effort. Jake
effort. Jake
- sideoilerfe
Re: re: Oil Filters
I do that when I can, like On my hi boy for example. But you can't fill it up if it is mounted sideways like in 2wd trucks with FE's.Jake11 wrote:When you put a new filter on, fill it up with oil. Let it soak in and keep
effort. Jake
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
re: Oil Filters
Um, I posted a link with a whole bunch of information in the second post...
- peanutman
Thanks DuckRyder for the link very informitive. All should read this link. I will be removing the fram from my engine and using a napa or wix filter from now own. Common sense should tell you cardboard and hot oil under presure don't mix.
- bobbyinpd
Re: re: Oil Filters
Same thing my grandpa taught me when I was 4, and I do it still on every change to this very day!Jake11 wrote:When you put a new filter on, fill it up with oil. Let it soak in and keep
effort. Jake
Best Filters are Mobil 1, Napa Gold/Wix(Same thing, just like Kap'n said).
Did you guys know that all the NAPA brand lubricants are just rebottled/labeled Valvoline products?
1996 F350 4 Door Dually Long Bed Power Stroke Diesel - K&N FIPK Intake, MBRP 4" Straight Exhaust, Diesel Turbo Lifesaver Turbo Timer, BriteBox.
1990 Escort 1.9L Stock
1958 Bel Air 4 door - FOR SALE
1975ish Camaro Autocross Car
1973 Camaro RS awaiting cage,backhalf, and 498 BBC
1969 El Camino - Wife's car
2004 Carson Trailer-to haul the goods!
www.bobby77.com
www.bobby77.com
- binder56jd
Re: Oil Filters
wix or napa gold
now serving #235
now serving #235
