i cant get the carberator mounting pegs off, ive squeezed them as hard as i can with vise-grips and cant get them to loosen up at all. are they pressed in?
i can try grinding down each side of a peg and getting grip that way with the vise-grips if they are indeed screwed in
reason i need them out is because were putting a carb spacer on
460 carb mounting pegs pressed or screwed in?
- 1971ford
- Joshpow
re: 460 carb mounting pegs pressed or screwed in?
They are just studs threaded on each end if I'm not mistaken. I am pretty sure they thread into the intake like any other carb stud. Have you tried WD 40 or something like that? I changed the ones in my 302 and they were tough to get loose, but not that tough. Have you ever tried a stud extractor? Sears has ste that grips the end of a stud and removes it. I used that to remove a head stud once. It worked great.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
Double nut them then soak in PB blaster. Hit each one a sharp blow straight down once with big hammer. Good luck
1968 F250 Camper Special 390
1964 Galaxie hardtop 352
1967 Cougar project
1993 F350 Crew cab 5.8
1988 Bronco 5.8 C6
1966 Mustang fast back project
New 1962 Falcon Gasser project
1967 Cougar project
1988 Bronco 5.8 C6
- 1971ford
He's saying that if you thread two nuts on those studs and tighten them together, you've essentially created a bolt....something you can use a wrench on. ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- 1971ford
Re: re: 460 carb mounting pegs pressed or screwed in?
i see, i just didnt get the part about the hammer. i understand hitting the wrench with a sharp blow to knock the thread loose, but hitting down?FORDification wrote:He's saying that if you thread two nuts on those studs and tighten them together, you've essentially created a bolt....something you can use a wrench on.
ill try wrenching on a double-nut though with a hammer
thanks
-Ryan
- Wes
After you pb blaster the stud if you strike the stud, you shock it and allow the penitent to soak in and possably loosen the rust.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them![Smile :)](./images/smilies/icon_smile.gif)
67 F250 High boy
69 Bronco
