This truck was mine back in 98, it had the same 390 (not quite as radical as now) and is pretty much the same truck. After being passed around to a few of my friends since then I finally got it back and am in the process of a complete rebuild.
I purchased another complete 69 for parts, I will be using the cab, inner fenders, and doors off the new truck. Everything else will be used from the existing truck.
I have decided on a flat black paint job (give it the rat roddish look), I also plan on a disc brake conversion, and some serious power under the hood. The 390 is bored 30 over, the heads are ported and polished, i am running a Comp Cam 33-250-4. Roller rockers, RPM intake, Holley Avenger 830cfm Carb., Holley black electric fuel pump, a fuel cell, MSD 6AL ignition box, and MSD Pro BIllet Distributor, headers, 4:10 gears in a 9" W/spool, TCI Super Street Fighter II torque Converter. (3,000 stall)
I will be mounting the fuel cell up under the rear with a fuel filler fabbed into the bed.
Any input, ideas, suggestions, let me know. It's all a work in progress.
WISH ME LUCK!
http://compcams.com/technical/Catalogs/ ... 31-232.pdf
