351 C
351 C
I picked up a '72 truck w/a 351c I knew it was a transplant but didnt expect the perches to be cut in half then welded to the cross member.
Are there a perch, motor mount combo that fits or will I need to start from scratch.
Will post pics tomorrow Mick
'68 F100
'69 F100
'80 320i
'02 superduty
'06 freestyle
'69 F100
'80 320i
'02 superduty
'06 freestyle
- ToughOldFord
- sideoilerfe
re: 351 C
The Cleveland should use the same towers as the 400.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
- ToughOldFord
re: 351 C
Someone correct me if I'm wrong, but I'm pretty sure the 351C uses the small block perches.
- Hawkrod
Re: re: 351 C
You are correct, a small block set of perchs and rubber mounts will bolt right to a Cleveland and set in as if it was built that way. As also noted, 351M and 400 perches are also the same thing but be aware that the 351M and 400 rubber mounts are different. HawkrodToughOldFord wrote:Someone correct me if I'm wrong, but I'm pretty sure the 351C uses the small block perches.
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- Hawkrod
re: 351 C
You are right that the perches from a 74 302 will work but a 400 is not a small block. The 351C is very closely related to a smallblock and so smallblock parts fit (even the pulleys and brackets from that 74 302 are the same for the most part!). A 400 is not really related to a smallblock or a 351C except for the cylinder heads although the pulleys and brackets are also the same. The 400 motor mounts are very different due to the fact that the block is a different design. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- lifted72
re: 351 C
Well, i have a 351 Cleveland in my 72 4x4, i used the perches out of a 78 with a 400. I also used headers for the same pickup, but had to do a little fab on them to make them work. 2wds should have wider frame rails though, so im really not sure about swapping those.
POLISH EVERYTHING
re: 351 C
Great help guys, I'll pull the motor and clean up the cross member then install the 302 perches to do this right. Its a fairly clean truck w factory air, new tires, mirrors, auto trans, and PS it needs PB. Then see whats next. I'll post pics.
I hope every one east of us gets through thie storm without a mishap!
'68 F100
'69 F100
'80 320i
'02 superduty
'06 freestyle
'69 F100
'80 320i
'02 superduty
'06 freestyle
re: 351 C
This needs more than I thought, belts, hoses, carb, wiring harness, no surprize. Valve cover's complete dizzy set up, maybe intake too. Shame the motor transplant was done by IGOR, otherwize this is a good truck. Is there a direct swap for a compressor (brackets aside).
I'll take camera today. Mick
'68 F100
'69 F100
'80 320i
'02 superduty
'06 freestyle
'69 F100
'80 320i
'02 superduty
'06 freestyle
- ToughOldFord
re: 351 C
You got your work cut out for you for sure, but it's worth it. Nice truck BTW!
Not sure what you're asking about the compressor though, you want to change from the type it has?
re: 351 C
after thinking about it does the serpentine setup from a roller 302 fit the cleveland? wishfull thinking I'm sure. The truck is real sound, Worth the effort I hope. It's a factory air truck and would like to update the air. ![Confused :?](./images/smilies/icon_confused.gif)
'68 F100
'69 F100
'80 320i
'02 superduty
'06 freestyle
'69 F100
'80 320i
'02 superduty
'06 freestyle
- 71PA_Highboy
re: 351 C
Maybe I missed something, but the burnt engine pic is not of a 351C.
Windsor block, not sure of the displacement.
So, did I miss something
eric
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
