I have searched all over the net, cant find any good info.
Would a Crankcase Evacuation system that vents Crank fumes into the exhaust work on a Daily driver? Will it work at lower RPMs? Being that its primarily for dragracing will it wear out quickly? I am asking because I want to get rid of my PCV valve.
Thanks fellas.
Question for the Drag racers
- j41385
1968 F100 Took the running 390 out, and installed a Built 300 with AOD.
Engine Video... http://youtube.com/watch?v=2xgYd2u79NU
re: Question for the Drag racers
Before the PCV, there was the "Road Draft" system, basically a tube to the atmosphere. Pretty much what you are going to do, with the exception of using the exhaust to "draw" the crankcase pressure out.
Why eliminate the PCV??
- j41385
Just doesnt seem beneficial to be putting those fumes into my fuel/air mix.
- aramil
sounds like a good plan, i wonder if the fumes do anything to the mixture?
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
Don't see where the "fumes" would hurt the air fuel mixture. Drag racres do it to keep from building crankcase pressure, which hurts ring seal. Remember , we' re talking about 8500+ rpm motors here.
Besides, if there is that much coming out of the crankcase vent thru the pcv system, i think you have other issues to worry about.
- Ranchero50
It's not a good idea. The PCV is supposed to recycle the burnt gases that get past the rings and valve seals. In fact it's drawing the oil laden air through the motor. On a friends 454 Chevelle the header vacuum would draw the oil out of the motor over 30 miles or so. Took a while to figure that one out.
Also if you run Total seal gapless rings they recommend a 1/16" restrictor port in the PCV because there is less gas getting by the rings.
Jamie
Jamie
