Self-etching primer
67 ford f100s rule
Self-etching primer
Post by 67 ford f100s rule »
What exactly does it do and what works best for price. Im also looking for filler primer to fix scratches in my bed rails and some tiny dents too.
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
td
re: Self-etching primer
Post by td »
etching primer actualy has a type of acid in it that ''etches'' it way in to the metal surface that prevents rust.
foghorn
Post by foghorn »
For your scratches and small dents i suggest this product As long as you have the surface roughed up a bit it will stick excellent. Remember this only does minor imperfections. It mix's just like bondo but sands easier. Just remember also a lil bit if hardener goes a long way in this hot weather this stuff kicks off really fast. To a golf ball size part of putty only use a 1/2" strip of the hardener.
http://www.evercoat.com/productDetail.aspx?pID=29
Foggy 8)
6T7Merc
Post by 6T7Merc »
It etches the paint giving i very nice base primer.
When i have a metal section i spray it with etcher then primer filler then sand. And as foghorn said, scuffing it up with sandpaper with help it bond tons more than without.
Im not sure what company would sell etcher for you since i use motomaster and that is canadian but for filler, duplicolour sells it and i have no complaints.
67 ford f100s rule
alright thanks for the help.i will be sure to pick some up so i can get Jeanne lookin straight again(so many imperfections and little dents).
Jeff Penland
foghorn
Post by foghorn »
Jeff the filler i linked you to can be applied over primer if you scuff it with180 or 220. Its much easier to see the little dings when it has a color on it. Stand to one side and let the light show it to you then circle it with a sharpie pen so you can find it later. This is how i always did hail jobs. The very first thing i did was this.
Foggy 8)
67 ford f100s rule
how much does it cost i cant find anything about price
Jeff Penland
foghorn
Post by foghorn »
If you have a finishmaster close to you call them or call your local auto body supply.
Lots of companies make the same kind of product but i like the evercoat best.
Foggy 8)
marine6212
Re: Self-etching primer
Post by marine6212 »
[quote="and some tiny dents too.[/quote]
to pull the tiny dents out use dry ice!! it shrinks the metal and pops the tiny dents out. I used it on some hail damage I received a few years back.
Semperfi,
Marine6212
We all came together, both young and old.
To fight for our freedom, to stand and be bold.
In the midst of all evil, we stand our ground.
And we protect our country from all terror around. Peace and not war, is what some people say. But I'll give my life, so you can live the American way. I give you the right to talk of your peace. To stand in your groups, and protest in our streets. But still I fight on, I don't bitch, I don't whine.
6T7Merc
Post by 6T7Merc »
duplicolour also sells a black primer which may show flaws even more. just fyi. :D
