Suggest a good oil additive?
- cathynkeith
I like Restore, on old engines I use it every oil change.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
- HH Henderson
re: Suggest a good oil additive?
I looked at "Power Punch" website and can order from them. But I would like to find this product in Parts Store. Does anyone know if they sell it in Parts Stores in Georgia.
HH
HH
"any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves Einstein
http://www.satisfaction.com/photobucket-login/
1968 Ford F100 360 cu (ole blue)
- HH Henderson
I have not been able to locate Power Punch. Do they sell this in local auto parts stores? I have e mailed the company, but have not had a reply from them......
But I did change the oil filter from a Fram to a Motorcraft and it helped a lot. so no more Fram for me.......
Thanks Guys.
HH
Thanks Guys.
HH
- binder56jd
hh- spoke with them on telephonic device today--u want a share of a case let me know--i want 2 try it 2--jd
call this a group buy--anyone else--speak up
ps--1 qt for a v8 per oil change--just like restore
pss--12 to a case 71+5 shipping to me--then split up so figure 10 +/- per qt dol(depending on location)
now serving #235
now serving #235
- HH Henderson
Hey Binder,
count me in for 1 quart, and if no one else wants any, I will take 2 or 3.
HH
HH
- BobbyFord
I've always felt that if any of the "snake oil" additives were benificial the oil companies would already have them in their oil. One of the main things that our flat tappet cam engines need is a high zinc content oil. Diesel-rated oils such as Chevron Delo or Shell Rotella contain a lot of zinc. Other high zinc oils are Royal Purple, Red Line, Valvoline VR1 Racing oil, Amsoil, etc. Almost all of the conventional engine oils for todays cars have drastically reduced zinc levels because the zinc in the oil kills catalytic converters. Also, cars built today have roller cams and do not require the anti-wear properties of the zinc that our flat tappet cams need. Synthetic and semi-synthetic oils also do not contain enough zinc.
If you run good oil you don't need an aftermarket oil additive.
- binder56jd
u r on the right track
i have gotten an extra 50k outta a shot engine with certain adds
it a matter of choice
ps and a matter of the issue your engine has
another afterthought--when u can see, hear and feel the difference--then said "snake oil" becomes a viable product and not just "snake oil"
now serving #235
now serving #235
