two barrel phenolic spacer needed.
- ezernut9mm
who makes them and where to buy? i've had no luck finding one. i have a factory aluminium one, but it is warped. it took two gaskets on the carb side to seal it and i still don't think it's sealed right. the carb is true-i checked that and it is good. also, who makes good rubber vacuum caps that don't disintigrate after a couple of months like the autozone ones?
![Image](http://i4.photobucket.com/albums/y150/ezernut9mm/68%20f100/HPIM1496-1.jpg)
![Image](http://i4.photobucket.com/albums/y150/ezernut9mm/70%20f100/HPIM2004-1.jpg)
![Image](http://i4.photobucket.com/albums/y150/ezernut9mm/67%20f250/HPIM2562-2.jpg)
- rubiranch
re: two barrel phenolic spacer needed.
Ford used them on 302s and 351s that were equipped with variable-venturi carburetors (2700 and 7200 VVs) from about 1979-1983.
Good luck.
Good luck.
- ezernut9mm
- basketcase0302
EZ,
For many years now I've taken the EGR valves and "gutted" them, plugged the 1/2" hole and used them for this.![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
Aluminum usually though, not phenolic.
- rubiranch
Nope, not the same bolt pattern.ezernut9mm wrote:i'm gonna need it. i haven't found one in any catalog except for a rochester 2bbl. i wonder if the bolt patterns are the same. prolly not.
