cant remove the front shock
- wildcard
re: cant remove the front shock
I had to remove all my bed bolts recently and some of the shoulders were rounded off and I couldn't get anything on the domed heads. A grinder with cutting a disc got up inside the frame and cut them in no time. I tried to get one from the top and accidently let it get into the bed. So now I have a 1 inch cut to get repaired in an otherwise solid bed.
If you have a propane torch you could try heating it up the best you can and let it cool. The heat will expand the metal and break any corrosion in the threads.
Dan
'69 F350 Crew Cab
'69 F350 Crew Cab
- Wes
On rusted shocks that are going to the scrap pile. I put a deep socket on rod nut then the longest extension I can fit, to use as lever and work it back and forth till the rod breaks.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- 1971ford
- binder56jd
as stated above right angle grinder
or
the liquid wrench--better known as the oxy/acetylene cutting torch
or
now serving #235
now serving #235
- mk
Last time I changed front shocks on a bump I used two visegrips at the top of the rod, under the spring mount. They had just enough grip to allow me to break the nuts loose. Suspension rust isn't a real big issue here though. A little bit of weasel whiz and a breaker bar are usually good enough.
mike
mike
Always drink upstream from the herd...
~Will Rogers
Mercury truck ID thread:
http://www.fordification.com/forum/view ... =2&t=35331
Ford truck model history:
http://www.fordification.com/forum/view ... =2&t=37394
Using dentside fender liners:
http://fordification.com/forum/viewtopi ... =7&t=35675
Matchbox diecast bumps:
http://www.fordification.com/forum/view ... =2&t=45618
~Will Rogers
- binder56jd
hey is that weasel whiz from the same outfit what makes panther p i s s ???
now serving #235
now serving #235
- mk
aye
mike
mike
~Will Rogers
~Will Rogers
