Pinch weld seam on firewall
- AK F100
I have started slowly scraping / cleaning the firewall of the 68 again and I noticed the pinch weld seam has been rusting a little and is swelling. I started to clean it out best as possible and was wondering what I should use to eliminate or cover the rust I can not get to and also what is best to seal it back up. I was thinking of using some sord of adhesive to bond it and seal it. Thanks for the help.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
re: Pinch weld seam on firewall
you might consider POR-patch. It's POR (Paint over rust) product and is a black goop like seam sealer. I'd degrease the area, clean it best I can and use POR patch.
If I didn't want to spend that much, I'd clean it and then use chimney sealing stuff in a tube from Lowe's, I use it alot. Seals great, seals out air/water. It's very reasonably priced.
- AK F100
Thanks. That is exactly the kind of info I was looking for. This build has turned into a penny pinching build. Instead of making it almost a show piece, it is going to be a nice daily driver. Can the chimney sealer be painted over or does it stay tacky, kind of like a tar type sealer.
Are there any other products other than POR-15 that work well also for covering rust?
GPBFD Pyro Maniac
- AlleyCat
Rust Bullet is sopposed to be good also.I used Rustoleum rusty metal primer on the frame of my DD a few years ago.I painted over it with Rustoleum black enamel.It's holding up fine.
Clay
- AK F100
Thanks AlleyCat.
GPBFD Pyro Maniac
- smclaren
It my experience that this rust on the firewall seam is coming from crap build up in the space beneath the window wipers. Clean that out with a water jet, let it dry, and then rust convertor on the area's affected on the firewall.
Then lather it in fish oil ...... including in the grill area below the windscreen. Use a hand pump spray gun.
Fish Oil
Fish Oil
1969 F100 4x2, RHD, Base Model, 240ci, 4sp, Dealer Canopy, No Bloody Radio.
u and ur fish oil. I hear it works but does it not smell like ****?smclaren wrote:It my experience that this rust on the firewall seam is coming from crap build up in the space beneath the window wipers. Clean that out with a water jet, let it dry, and then rust convertor on the area's affected on the firewall.
Fish Oil
- AK F100
I will definately clean that area out as soon as I can roll it outside. So, the fish oil stuff really works, does it have any smell or is it odorless?smclaren wrote:It my experience that this rust on the firewall seam is coming from crap build up in the space beneath the window wipers. Clean that out with a water jet, let it dry, and then rust convertor on the area's affected on the firewall.
Fish Oil
GPBFD Pyro Maniac
- AK F100
Thanks for the tip.
GPBFD Pyro Maniac
- AlleyCat
That might be why Rustoleum holds up.One of it's ingredients is fish oil.
Clay
