MLJJONES67 PROJECT CUMMINS put away for winter
Dustin,
You think this one will work if I trade him? Just wondering to help this guy out??
http://www.4btswaps.com/forum/showthread.php?t=4128
- averagef250
Mike, either will work, but the one you have the better choice for any installation.
The one he has is not a first gen. It's a 94-02 hub. The Factory ford fan shrouds are made to conmpensate for the engine being offset in the frame 1 3/4" and the fan being centered over the crankshaft. The mount you have centers the fan over the crank, that puts the fan where it's supposed to be.
Those fan mounts are on ebay continuously. I wouldn't think he'd have a hard time finding one.
re: mljjones67 project update
Any body out there used energy suspension cab mounts?? If so how do you like them? Also where did you buy them?? I need a set for the 67 to 79 frame swap i am doing. Are the mounts the same for these years??
Thanks all!
Thanks all!
- averagef250
- averagef250
- RedneckTexan
I am thinking of going and looking at this one. What should I look for that would steer me away from it??
http://www.ksl.com/index.php?nid=218&ad ... cat=&lpid=
Wont there be enough room once the engine fan is removed?averagef250 wrote:Are you going to intercool it? You can't run electric fans and an intercooler, there isn't enough room. The engine fan cools much better too. You can't lose the pulley, the belt has to run on something.
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
'72 crew 4x4
'07 KTM 450 xcw
- averagef250
I don't follow. You need to have a fan. The engine driven fan takes up a lot less room than electric fans that will equal it.
It's a very tight fit, but not impossible. Your core support will not be the same after fitting an intercooler/radiator.
If you're really strapped for room you can get rid of the fan clutch and run a solid mount fan. You can get an extra inch, but you'll lose atleast a MPG mileage.
Turbo i need to look at
re: mljjones67 PROJECT CUMMINS UPDATE
Small update,
Donor truck almost ready for sand blasting. Hopefully the cab will come off tomorrow. Here is some pics
mmmmmm rear gas tank. Love it!
Here is the in frame. i will be putting the 67 in frame one in, in place of this one.
More update tomorrow and a few pics of the some new parts for the cummins!
