FE with power steering
OLE69F100
Post by OLE69F100 »
I just read the adding power steering tutorial and was total bummed to find out that I could not run headers on my 69' with the factory power steering and the bendix box :x are there no headers that will work? I guess I should also ask if you can use headers with a 302 or a 460 with the bendix box. I don't want to spend the money on a new steering set up when I already have one. :cry:
1969 F-100 SHORTY W/390 IN PROCESS OF REBUILD
kaptnkaos
re: FE with power steering
Post by kaptnkaos »
Hey Ole'69...
I am pretty sure you can run hedders on yer 390 w/PS.
My brother, TheeMc, put Hedmans on his '72 CS w/390 and PS...
I have seen several rigs with both...
Maybe it was a particular brand hedders or something.
I know they say that you can't put hedders on a '68 CS either...
But mine had them on it for the past 20 years...
I recently went back to stock manifolds, simply becaseu I had a nearly brand new stock style performance exhaust system on the '71 CS I parted out...
I just did the PS upgrade on my '68 CS... it's well worth the effort.
KaptnKA 8) S
OLE69F100
Post by OLE69F100 »
Thanks for the reply Kapt. What steering gear does he have the bendix or the saganaw? It say's in the tutorial its only with the bendix :x
mrtleavitt
Post by mrtleavitt »
Ya, I don't know where you got that info but my brother has a saginaw setup and headman headders, and I run the saginaw with some hooker headders we haven't had a single problem with our power steering with our 390s
sideoilerfe
Post by sideoilerfe »
Saginaw box you can run headers. Bendix cannot. Try these:
the top three models.
http://www.sandersonheaders.com/index.p ... 1_24_40_44
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
Maltybuck
Post by Maltybuck »
I'm not a guru so take it for what it's worth, but the 1969 that I bought last summer has a 390 with headers and a Bendix PS box. Unfortunately, the PS gearbox has a massive leak, but it has a tag on it stating it was rebuilt in June of 2006. I suspect that the additional heat from the headers caused the premature blowout of the PS box. The headers are probably about 15 years old, so maybe that brand/style is no longer available.
Just my two cents...
