Hump cover
iamthewreckingcrew
Hump cover
Post by iamthewreckingcrew »
Do all bumps have a removable trans hump cover? I've never had my floor mat up. I'm thinking of putting a nice reverse lockout floor shifter in, but I don't want to cut holes. If they all have the removable panel, I'll just get a junkyard one and cut a hole in it for the new shifter.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
SteveC
re: Hump cover
Post by SteveC »
my 67 that is a auto...as far as i could tell it wasnt removeable. But that may be a 67 thing
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1971ford
Post by 1971ford »
my 69 is an auto, has a removable hump.
-Ryan
SteveC
re: Hump cover
Post by SteveC »
ill take a look at the the two bumps a will be aquireing very soon a 70(i think and a 71 or 72. Both were setting south of dads and we could never get a hold of the guy but we finally did and he said hed sell them for scrap price...ill check them to see if they have a removable hump.
Or if it is just my 67 odd ball
1967 f-100 4x4
67mann
re: Hump cover
Post by 67mann »
:? Just for my own Knowledge---aren't those shifters,cable activated and would only require a hole drilled? Atleast the one I had in a car(long time ago)was. Or not all of them work that way?
iamthewreckingcrew
re: Hump cover
The ones I've looked at are cable type. I just really don't want to drill any holes in my original sheetmetal if I don't have to.
Could I tell from underneath if my truck has the removable hump?
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
67mann
re: Hump cover
Post by 67mann »
I would think you would see the ends of sheet metal screws---just a thought.
mk
Post by mk »
The 4spd/4x4/c6 trucks had the cover because of the bigger transmissions but the 3spd and smallblocks with C4 trans didn't.
mike
Always drink upstream from the herd...
~Will Rogers
Mercury truck ID thread:
http://www.fordification.com/forum/view ... =2&t=35331
Ford truck model history:
http://www.fordification.com/forum/view ... =2&t=37394
Using dentside fender liners:
http://fordification.com/forum/viewtopi ... =7&t=35675
Matchbox diecast bumps:
http://www.fordification.com/forum/view ... =2&t=45618
prostreetjim
re: Hump cover
Post by prostreetjim »
has anyone had to cut the floor out to install a hump to get the extra space needed when putting in a C6. what is involved and will a dent fit a bump hump :? :lol:
71Ford100
re: Hump cover
Post by 71Ford100 »
I wouldn't think you would have to cut up a cab that originally had a small block or c4 but idk I have never had one that did not have the removable hump.
Lance Peters
