urethane bushings?? which ones?
kilog55
Post by kilog55 »
if i were to replace all the rubber with urethane ones from ES what would i need to get and how do you figure out the degree offset?
1972 f100 2wd L6
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
trickf100
re: urethane bushings?? which ones?
Post by trickf100 »
To do everything on the suspension you will need axle pivot bushings, radius arm bushings, and rear leaf spring bushings. Make sure you specify to the manufacturer if you have normal shackle rear springs or if you have the flex-o-matic rear springs. The bushings are not interchangeable. You can replace the cab mounts with poly as well as the steering linkage boots with poly boots.
As far as degree bushings goes that only applies to the c-bushings on 1/2 ton four-wheel drives.
1968 f100 Ranger
1972 f100 Sport Custom
1972 f250 4x4 conversion
kilog55
Post by kilog55 »
yeah i have the flexo, so the "kit" comes with all the right bushings then? i know the quality of each company is very good. i have seen on ebay flexo kits so tehy make em just gotta find em.
trickf100
Post by trickf100 »
I don't know about energy suspension but I got the prothane kit and it DID NOT have the correct rear spring bushings. I ended up spending $80 and getting the flex-o-matic poly-graphite bushings from PST.
1968 f100 Ranger
