new brakes
fourtss
new brakes
Post by fourtss »
I bought a set of new brake shoes for the boys 90 4x4, use to be the brakes were two different sizes (back axle) large shoe for the front side small one for the back, this set I bought the shoes were all the same size (small shoes) anyone come across this before, or did I get a set that wasn't right? :dk:
I bought the set from auto zone
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
iamthewreckingcrew
re: new brakes
Post by iamthewreckingcrew »
I'd be suspicious of the wrong parts. One shoe per set should be bigger.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
tfnaaf
Re: new brakes
Post by tfnaaf »
fourtss wrote:I bought a set of new brake shoes for the boys 90 4x4, use to be the brakes were two different sizes (back axle) large shoe for the front side small one for the back, this set I bought the shoes were all the same size (small shoes) anyone come across this before, or did I get a set that wasn't right? :dk:
Just an FYI the small shoe goes to the front side, and yes they are supposed to be different sizes. sounds like they got you the wrong ones. Or they are miss boxed.
Here is a DIY......
http://www.geocities.com/tomnaaf/images ... mbrake.pdf
ToughOldFord
re: new brakes
Post by ToughOldFord »
I don't think fourtss is talking about primary/secondary shoe per wheel, he's asking if the rear axle should have smaller brakes than the front. I've seen what he's talking about, but I don't think that's the rule.
Also, I have seen replacement shoes that do not have the shorter material on the primary side, all 4 shoes are the same side. Don't know how they did with without grabbing, but they don't.
tfnaaf
Re: re: new brakes
Post by tfnaaf »
ToughOldFord wrote:I don't think fourtss is talking about primary/secondary shoe per wheel, he's asking if the rear axle should have smaller brakes than the front. I've seen what he's talking about, but I don't think that's the rule.
lol, i guess it all depends on how you read his post.... guess we'll wait till he responds
fourtss
re: new brakes
Post by fourtss »
well lets see, I'm talkin bout the rear axle, the primary shoe versus the secondary shoe, use to be they were different sizes, the shoes I got were all the small shoes, so I don't know if the manufacture got it wrong or if they changed the format and say you don't need two different size shoes on a wheel anymore,at any rate I think I have my problem solved, best I can figure the drum is warped so I'm replacin that today, so hopefully this will correct the problem :dk: cause I'm tired of :hw: :doh:
tom
2003 ford escape
fourtss
re: new brakes
Post by fourtss »
yea and I got these from auto zone, never again :cry:
tom
2003 ford escape
tfnaaf
Post by tfnaaf »
they should be different primary adn secondary shoes on you truck, If they are not then take them back and get the correct ones
ToughOldFord
re: new brakes
Like I said, I have seen replacement linings that were all the same length. But so far they all have been the longer linings like the original secondaries. Never seen them all being short yet though.
I'd just take a look at another set, if they're the same I wouldn't worry about it.
rjewkes
Post by rjewkes »
well now they couild have a batch of wrong ones there too.
autozone.com shows(providing this is an f150) a set with shorter material pads and the two normal length pads. is the same for 2wd and all three engine sizes.
if itys a baby ranger(as i call them) it show diff part but same idea one each side of axle short material and one long material. i bet someone at the manafacturer boxec two small ones together.
tfnaaf
Post by tfnaaf »
out of the 100-50000000000 rear brake jobs i've done on f150's they ALL had small front shoe and large back brake shoes on same axle
fourtss
re: new brakes
Post by fourtss »
figured out what the overheating problem is, the bearing is gone on axle :cry: forgot to mention that the hub and brakes were smokin hot, that's what got me curious, :doh:
tom
2003 ford escape
ToughOldFord
tfnaaf wrote:out of the 100-50000000000 rear brake jobs i've done on f150's they ALL had small front shoe and large back brake shoes on same axle
:roll:
