smallest wire wheel?
worldsmysterie
Post by worldsmysterie »
is there a good wire wheel that can get in the seem that goes down the side of the bed of the truck.
MadMaxetc
Post by MadMaxetc »
I use the little one that goes in a Dremmel, if you don't have one just put it in your drill.
They are about 1" in diameter and about $3 each.
Dan
FORD Girl
Photobucket Pictures
you might find that a wire brush might not work for that. what you might have to use is a cut off wheel for a dremel. it is thin enough to get in there.
rjewkes
Post by rjewkes »
:yt: I have a die grinder with a cut off wheel. gently pressed into the seem it only seems to sand the metal and cut out the seam filler. does blow it every where though.
MaxKlinger
re: smallest wire wheel?
Post by MaxKlinger »
Be real careful when using cut off wheels. You could end up cutting things you don't want to cut.
Also, cut off wheels, especially the ultra-thin dremel ones, are very brittle and break easily.
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
rjewkes
Post by rjewkes »
:yt:
