Lowering
- Joshpow
Lowering
I know this isn't the correct way to lower the twin I-beam front axles. Anyone lowered the front 2 inches by cutting springs. I know Keith addressed this in his lowering page, but I would like to see pics. Also I wondered how much cut off it takes to lower that much. I am going to put a 77 disc front end in it and I want to lower it as I put that in. I want as little trial and error as possible, so I need o good estimate to go with. If anyone has experience with this, I'd really appreciate input.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
re: Lowering
There's nothing wrong with cutting the coils to lower the front end, as long as you use something like a cut-off tool (or even a hack saw) to minimize heat build-up, which will destroy the temper in the springs and ruin them.
Keep in mind that cutting the springs will negatively affect the camber. Since the camber is set at the factory and not easily adjustable the only correct way of fixing this is to find a shop capable of bending the I-beams.
On my choptop I cut two full coils from the front springs and it did lower it several inches, but I can't give you any more specific details on the exact amount of drop, since I did it without an engine/transmission installed. I'd guess that two full coils dropped it between 2" and 2-1/2".
- kilog55
what did you use for the rear? flipped shackles or remove leafs?
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
- ezernut9mm
- Joshpow
re: Lowering
Ezernut, Yhanks for the info. How much did it lower the rear when you flipped the shackle mounts?
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
