Another Frame Question!
Hey,
Would a '72 F-100 Shortbed frame be any different than a Longbed frame other than length? The reason I ask is that my '72 was shortened from a long bed and I just got a true '72 (supposedly) shortbed frame. The front crossmember looks a lot different on my old frame than it does on my new frame. My new frames crossmember looks just like the one on my '68. Are there any differences in the front crossmembers between '67 and '72? I'm trying to figure out what year the old frame that was chopped is. Any ideas? I would like to know because this truck has obviously gone through a lot and im finding out new crap that the PO did to her everyday.
Thanks,
Corbin
Thanks,
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
re: Another Frame Question!
get the vin number off of the right side frame. should be behind the spring perches. that vin will tell you what year the frame is.
Ok I'll go see what I can find.
The vin on the old frame is F10GRN65116 and it matches the vin on the door. I can't make out the vin on the new frame.
Corbin
Corbin
f10 - f100
g - 302 v8
r - san jose cal.
n65116 - mid year 1972
this is all i got from the vin#
that other frame # is probably painted over.
g - 302 v8
r - san jose cal.
It seems to be a '72. Would the longbed frames be any different than the shortys or do you think my new frame is older and the design was different in '72? The difference that I am seing is the front crossmember on my old frame doesn't have the hollow part before the i beams bolt in. Also the rear shock mounts are like the ones on my '68 and not the '72 style.
Corbin
Corbin
the two shortbeds i had and have now are like that. with the holes in the front cross member. now my f250 is not like that though. i think it might have to do somthinig with weight reduction. like lightening holes.
Yeah, I'm just wondering when the change was made. If some had the hollow part and some didn't or if they changed at a certain point. It's a lot easier to jack up the frames that have the bigger crossmember due to the larger area on the bottom.
Corbin
Corbin
Hey,
I was able to find the vin in the second spot on my new frame. It reads F10ARB45935 and that would say that is a '67 with a 240. Right now it has 302 perches so it must have had a swap sometime down the line. So when did the frames change their design? I though they were all the same but it seems my '72's front crossmember is a lot different than that of a '67. I wont have a problem bolting by '72 body to the frame will I? Everything looks like it will fit just fine. Any ideas?
Thanks for the help,
Corbin
Corbin
67-72 bodies to frames are all changeable. now 73-79 frames will be where you have to modify the bed mounts a little bit. that is what i'm gonna have to do for my 70swb.
My new frame looks to have 302 perches on it now and they are only held in with three bolts so maybe the PO threw in a 302 and didn't drill new holes for the perches. Who knows. As long as I do it right when I build it thats all that matters.
Corbin
Corbin
there you go
