Ignition Lock
69F110
Ignition Lock
Post by 69F110 »
Anybody know how to break the ignition lock on a 1990 Ford Bronco with titl steering?
I acquired the vehicle from a fellow Soldier...unfortuneatley he is in Iraq and his keys are in storage in Michigan. To add to the craziness, the Police tagged it as abandoned and will tow it in 72 hours from today...
I have a new ignition cylinder to put in it, but can't get the old one out. I have no official paperwork on the truck yet, so the local locksmith won't help due to "liability".
I have no background in "breaking the ignition cylinder" and have no clue.
Any Guidance?
Steve Davis
Pastor and U.S. Army Retired
1969 F100 Ranger LWB, 390 and 3 on the tree
1971ford
Post by 1971ford »
WELCOME! you will love this place, lots of good info lol
are you welcoming the idea of a new ignition lock?
-Ryan
Wes
Post by Wes »
After you get the Plastic covers off, you should fine a 3/16"ish hole on the under side of the lock cylinder housing. This hole is for the cylinder lock button. you will need to drill this button bye bye. once you do that you can easily pop the cylinder out w/ a small slide hammer breaking the "T" off the end of the cylinder. Fish broken piece out w/ needle nose pliers. Ok now the new cylinder goes in w/ key in and in run position, but your switch is in off position, you need to turn it to run position w/ bent rod or screw driver.
This task is a pain in the A**, It would be worth a try to rake the tumblers till you can turn the switch to run. then just push the button slide old cylinder out slide new one in. hope this helps.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them :)
69F110
Post by 69F110 »
It does help...too bad I posted in the wrong forum...I think that's a first in over 2000 posts.
Oh well, I was thinking more about the bronco than the posting.
I'll give it a whirl tomorrow, see how it works out.
Thanks!
Steve Davis
wt4speed#2
Post by wt4speed#2 »
69F110 wrote:It does help...too bad I posted in the wrong forum...I think that's a first in over 2000 posts.
Thanks!
Bye the way Steve welcome. I was readin this thinking why 1971ford is bust your ba!!s with your post count , then i read your post didn't even realize i was in the welcome mat too. :lol: :lol:
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
69F110
Post by 69F110 »
Crazy huh? I went to the General Discussion and was looking and looking for my post to see if anyone replied....I was thinking "What in the world happened"...then I recalled welcoming some folks before posting...the rest is history.
Anyways, Thanks for the Welcome! I haven't been welcomed since July 04...
Steve Davis
RedneckTexan
Post by RedneckTexan »
1971ford wrote:WELCOME! you will love this place, lots of good info lol
:lolprev: :lolprev: :lolprev: :lolprev:
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
foghorn
re: Ignition Lock
Post by foghorn »
I was gonna suggest the slide hammer method also. But i was gonna say take a pair of channel locks and turn the butterfly off the end and screw the slide hammer in good and tight then yank it hard and fast. I dont remember if it was the ford or the gm's that had the hardened pins in the ignition. You might have to use the channel locks to get it good and tight. But im leaning towards the fords having the hardened pis so i would drill it like the other member says. just make sure you have a very sharp bit to drill with and use a punch to mark it with so it stays in place. I hope this info helps and that it works out ok for you.
Foggy 8)
69F110
Post by 69F110 »
I did not get to it yet...crazy Army expects you to work when they tell you to...been late getting off every day this week.
I'm going to hit it Thursday evening with the drill.
Turns out the towing contract for the post expired, so I have a few days to play with.
Also, I found the title in the truck, so all I have to do is wait for previous owner to come home on R&R and sign it over to me. Sweet. it takes an eternity to file for lost title in Louisiana.
Steve Davis
